Problem installing ka-map 1.0 with ms4w 2.2.2
Jeff McKenna
jmckenna at DMSOLUTIONS.CA
Mon Jun 11 07:21:13 EDT 2007
Note that the MS4W downloads page has its own ka-Map package available
that is already configured for MS4W.
jeff
carlos gordon wrote:
> Hi all!
> I´m trying to configure it the installation of ka-map with ms4w but i
> have many troubles making it works properly, at first these are the
> steps i follow:
> 1. Creation of mapfile
> 2. Configured the Apache web alias
> 3. Before that i have to run the setenv.bat file to set the .dll path
> 4. Defining alias and restartig Apache:
> Alias /kamap "/ms4w/apps/ka-map-1.0/htdocs"
> <Directory "/ms4w/apps/ka-map-1.0">
> AllowOverride None
> Options Indexes FollowSymLinks Multiviews
> Order allow,deny
> Allow from all
> </Directory>
> 5. Configuring config.php
> First, pointing to php modules:
> $szPHPMapScriptModule = "php_mapscript_4.10.0.".PHP_SHLIB_SUFFIX;
> $szPHPGDModule = 'php_gd2.' .PHP_SHLIB_SUFFIX;
> Later, defining the map array
> $aszMapFiles = array(
> "PanamaMap" => array( "Provincias Panama",
> "/ms4w/apps/kamap-1.0/htdocs/mapas/map/panama.map",
> array( 250000, 120000, 75000, 30000,
> 10000 ),
> "PNG")
> * szMap should be set to the default map file to use but can change if
> * this script is called with map=<mapname>.
> $szMap = 'PanamaMap';
> Setting the directories for cache
> * for the application (see mapfile configuration above.)
> $szBaseCacheDir = "C:/ms4w/tmp/ms_tmp/";
> /* Uncomment the following if you have a web accessible cache */
> $szBaseWebCache = "../tmp/ms_tmp/";
> But it doesn´t seem to work properly, because when i go to
> http://localhost:8080/ka-map/, the browser IE 6.0, send me this message:
> Line: 76
> Char: 1
> Error: Object expected
> Code: 0
> URL: http://localhost:8080/ka-map/
> I'm using the ms4w 2.2.2 version and ka-map 1.0 on Windows XP 64x
> I have like one week figthing with this problem, because i need to
> configure kamap to create tiles and use it with Open Layers as a web
> client in my project.
> Thanxs in advanced,
> Carlos A. Gordón
> Especialista en GIS
> Tel. (507) 665-49715
> cagb78 at nuzkiamedia.com
> Vía Sonadora, casa 5,
> Penonome, Provincia de Coclé
> Panamá
Jeff McKenna
DM Solutions Group Inc.
http://www.dmsolutions.ca
