Problems in testing Java Mapscript
Victor Herrero Cazurro
la_barrenadora at HOTMAIL.COM
Tue Jun 12 06:02:27 EDT 2007
Hello,
You have a environment variable "PROJ_LIB = C:\ms4w\proj\nad"?
bye
>From: Umberto Nicoletti <umberto.nicoletti at GMAIL.COM>
>Reply-To: Umberto Nicoletti <umberto.nicoletti at GMAIL.COM>
>To: MAPSERVER-USERS at LISTS.UMN.EDU
>Subject: Re: [UMN_MAPSERVER-USERS] Problems in testing Java Mapscript
>Date: Tue, 12 Jun 2007 11:35:43 +0200
>Search for other mapscript.dll. There should be another that does not
>require sde.
>Umberto
>On 6/7/07, Gaia Trecarichi <gaia.trecarichi at gmail.com> wrote:
>> Hello,
>>I have some problem in testing Java Mapscript.
>>I answer some questions posted by Umberto and Rodrigo (thanks for the
>>reply):
>>- Probably there is a problem with sde91.dll because , using
>>Dependency Walker to scan mapscript.dll, it is found that sde91.dll is
>>missing. I cannot understand why mapscript.dll need sde91.dll since
>>I'm not using arcSDE. In case I need it, how can I download it?
>>- Yes, I have rebooted Windows after changing SYSTEM path variable
>>- Yes, I'm sure the path is set correctly in the SYSTEM variable
>>If someone knows the correct list of the dll needed, please let me know.
>>Below is reported in plain text the original email I sent some days ago:
>>Hello,
>>I'm new in mapserver stuff and I'm trying to use Java Mapscript
>>without any success.
>>My environment is:
>> * Windows XP
>> * MS4W version 4.10.1.
>> * JDK 1.6.0_01
>> * Eclipse
>>I wanted to test some Java Mapscript functionality with a simple Java
>>program whose code is the following:
>>import edu.umn.gis.mapscript.*;
>> public class ProvaMapscript {
>> public static void main(String[] args) {
>> String mappath= new String("C:\\ms4w\\apps\\e-rescue\\" );
>> mapObj map = new mapObj(mappath.concat(" emergency2.map"));
>> imageObj image = map.draw();
>> String image_url = "C:\\ms4w\\tmp\\ms_tmp\\emergency.png";
>> image.save(image_url, map);
>>I get the following error:
>>Exception in thread "main" java.lang.UnsatisfiedLinkError: C:\Program
>>Files\Java\jre1.6.0_01\bin\mapscript.dll: Can't find dependent
>>libraries
>> at java.lang.ClassLoader$NativeLibrary.load(Native Method )
>> at java.lang.ClassLoader.loadLibrary0(Unknown Source)
>> at java.lang.ClassLoader.loadLibrary(Unknown Source)
>> at java.lang.Runtime.loadLibrary0(Unknown Source)
>> at java.lang.System.loadLibrary(Unknown Source)
>> at edu.umn.gis.mapscript.mapscriptJNI.<clinit>(mapscriptJNI.java:23
>> at edu.umn.gis.mapscript.mapObj.<init>( mapObj.java:276)
>> at ProvaMapscript.main( ProvaMapscript.java:51)
>>I don't know exactly which libraries mapscript.dll requires but as far
>>as I could see from some forum the following list of dll's is needed:
>>bgd.dll
>>gdal14.dll
>>geotiff.dll
>>iconv.dll
>>kernel32.dll
>>libcurl.dll
>>libecwj2.dll
>>libmap.dll
>>libmysql.dll
>>libpq.dll
>>libproj.dll
>>libtiff.dll
>>mapscript.dll
>>msvcr71.dll
>>msvcrt.dll
>>ntdll.dll
>>pdflib.dll
>>proj.dll
>>xerces-c_2_7.dll
>>zlib1.dll
>>dwmapi.dll
>>I have them in the directory "C:\ms4w\Apache\cgi-bin" and this
>>directory is in the system environment variable PATH.
>>I don't know exactly which is the problem. I'm thinking to 2 things:
>>1- As far as I can understand there is a library, namely sde91.dll,
>>that is needed by libmap.dll. I can't find this library in my
>>system. Is there anybody who knows where I can download this library?
>>(but I think I don't need it since I'm not using ESRI's ArcSDE)
>>2- Is it possible that my Java Mapscript files are not compatible with
>>my JDK version 1.6.0? I say it because I read in the
>>README_INSTALL.txt of MS4W the following:
>>MapScript
>>Java MapScript: compiled against Java 1.5.07
>>If anybody could help me in this problem I would be infinitely grateful!!
>>Thank you in advance,
>>Gaia
_________________________________________________________________
Moda para esta temporada. Ponte al día de todas las tendencias.
http://www.msn.es/Mujer/moda/default.asp
