One shapefile, many countries, many colors?
karsten vennemann
karsten at TERRAGIS.NET
Wed Jun 13 21:09:49 EDT 2007
Subject: Re: [UMN_MAPSERVER-USERS] One shapefile, many countries, many
colors?
Pascal Ehlert wrote:
> Hi all!
> I used shp2pgsql to insert the definitions of many countries (the
> African continent actually ;)) into my PostGIS enabled database.
> Is there still a way to distinguish between the countries now and assign
> different colors to them?
> ArcView does this in a really nice way so I think it should be possible
> with the MapServer too, isn't it?
> Thank you
> Pascal
> Yes, basically you would have to set up a column in the query to be a
> CLASSITEM and have the column represent the color you want. Then in the
> mapfile set up colors for each class.
> -Steve W.
As an example I am usually using something similar like this:
LAYER
NAME "Countries"
GROUP "Africa"
TYPE POLYGON
STATUS ON
CONNECTIONTYPE postgis
CONNECTION "user=me password=none dbname=africa host=localhost"
DATA "the_geom from (select the_geom, countryname, area, gid from
africa_countries) as temp using unique gid using SRID=4326"
# SRID 4326 is when using decimal degrees, replace with the correct SRID
for your data
CLASSITEM "countryname"
CLASS
NAME "EGYPT"
COLOR 153 204 143
EXPRESSION ([countryname]=EGYPT)
END
CLASS
NAME "LYBIA"
COLOR 252 141 50
EXPRESSION ([countryname]=LYBIA)
END
CLASS
NAME "MADAGASCAR"
COLOR 255 190 232
EXPRESSION ([countryname]=MADAGASCAR)
END
END
Cheers
Karsten
