Mapscript/PHP help me display tabular results of my query
(queryByAttributes)
Pietro Giannini
pgiannini at BYTEWISE.IT
Thu Jun 14 03:34:15 EDT 2007
Hi John,
the result of "$layer->getResult($i)" is a result cache; you must obtain
the shape of the layer by the "shapeindex" property of the result cache:
your code:
$layer->open();
for ($i = 0; $i <= $layer->getnumresults();$i += 1) {
$resultx = $layer->getResult($i);
// THIS Does NOT give me what I'm after
print "<pre>";
print_r($resultx); // print_r($resultx);
print "</pre>";
modified:
$layer->open();
$shape = $layer->getShape($resultx->shapeindex);
print "<pre>";
print_r($shape->values['string_name_of_the_field']);
print "</pre>";
take a look here:
http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/layerobj
http://mapserver.gis.umn.edu/docs/reference/phpmapscript-class/classes/resultcachememberobj
bye
................................pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
> Hi,
> I have been looking through the Mapscript API and can't find what I'm
> looking for. I'm just asking for help with a tip as to where to look.
> I'm trying to display the results of my query.
> ++++++++++++++ BEGIN CODE ++++++++++++++++++
> <?php
> dl('php_mapscript.dll');
> list($layername, $field) = split(",", $_GET['q']); // q is the value of
> what was selected
> $options = array();
> $map_path="C:\\ms4w\\Apache\htdocs\\img_browser\\";
> $map_file="imgb_access.map";
> $map = ms_newMapObj($map_path.$map_file);
> switch($layername) {
> case 'landsat_4':
> $layernum = 3;
> $qstring = "Landsat";
> break;
> case 'ikonos':
> $layernum = 4;
> $qstring = "Ikonos";
> break;
> case 'hyperion':
> $layernum = 5;
> $qstring = "Hyperion";
> break;
> case 'mn_airphotos':
> $layernum = 6;
> $qstring = "MN DNR";
> break;
> $layer = $map->getlayer($layernum);
> $success = $layer->queryByAttributes($field, $qstring, MS_MULTIPLE);
> $layer->open();
> print "<pre>";
> print "</pre>";
> ++++++++++++++ END OF CODE ++++++++++++++++++
> The last section (with print_r) shows me the result of my query but not
> in the form that I want. I want to see the records in the dbf table of
> the shapefile that I have queried. What am I doing wrong ?
> John B. Churchill, M.S. http://alx.al.umces.edu/~jchurch/
> GIS Specialist (301) 689-7109
> University of Maryland Center for Environmental Science
> Appalachian Laboratory http://www.al.umces.edu/
> Environmental Science Education http://alese.al.umces.edu/
> 301 Braddock Road
> Frostburg, MD 21532
