can layers be linked?
LITTLE Nelson
nelson.little at TENIX.COM
Tue Jun 19 02:41:01 EDT 2007
Hi Guillaume,
Thanks for your reply. Unfortunately I am using Java MapScript and there is no "getLayersIndexByGroup" or similar functionality.
Thanks,
Nelson
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Guillaume Sueur
Sent: Monday, 18 June 2007 5:24 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] can layers be linked?
Hi Nelson,
You can use the GROUP attribute for each layer, setting it to the same
value (ex : GROUP "COMPOSITE")
they'll not be linked, but you'll be able to retrieve thse layers using
the group name :
$aLayers = $pMap->getLayersIndexByGroup("COMPOSITE")
and then loop on the $aLayers array to switch then on/off
Regards,
Guillaume SUEUR
LITTLE Nelson a écrit :
> Hi,
> I would like to link two layers of different geometry types. 1 layer
> contains points, the other layer contains lines. The points and lines
> are shown together to display a composite object on a map. If the user
> no longer wants to see that composite object on the map then I would
> like to turn off both of the layers. I am sure I can do it
> programmatically, but I would like to know if they can be linked in the
> MapFile?
> Thanks,
> Nelson
Guillaume SUEUR
Disclaimer :
The contents of this e-mail including any attachments are intended only
for the person or entity to which this e-mail is addressed. If you are not,
or believe you may not be, the intended recipient, please advise the sender
immediately by return e-mail, delete this e-mail and destroy any copies.
Tenix does not warrant nor guarantee that this email communication is free
from errors, virus, interception or interference.
