ROSA pan
Eduardo Zenaide
ezenaide at GMAIL.COM
Tue Jun 19 16:42:26 EDT 2007
other question: i'm trying to use chameleon just to understand the widgets.
i've already put the files and create the conf file. happens that all pages
give this error:
*Warning*: fopen(c:/tmp/ms_tmp/9b39e07d9c2fa23a768d6ef41c196df3_mlt.inc.php)
[function.fopen <http://localhost:82/chameleon/samples/function.fopen>]:
failed to open stream: No such file or directory in *
C:\ms4w\apps\chameleon\htdocs\common\mlt\mlt.php* on line *743
**C:\ms4w\apps\chameleon\htdocs\common\mlt\mlt.php* is correct. what could
it be?
thanks in advance
2007/6/19, Eduardo Zenaide <ezenaide at gmail.com>:
> can i use it without using chameleon adding it to other application?
> 2007/6/19, Jeff McKenna <jmckenna at dmsolutions.ca>:
> > You might have better luck using something like Chameleon which has a
> > pan widget out-of-the-box.
> > jeff
> > Eduardo Zenaide wrote:
> > > hi,
> > > how can i use a nice pan with ROSA applet?
> > > like, instead of that 'recenter' tool, could i be able to pan?
> > > Eduardo Zenaide
> > Jeff McKenna
> > DM Solutions Group Inc.
> > http://www.dmsolutions.ca
> Eduardo Zenaide
Eduardo Zenaide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070619/8b00cc56/attachment.html
