More GDAL problems
Alan Hale
alan.hale at BTCLICK.COM
Thu Jun 28 11:08:37 EDT 2007
> -----Original Message-----
> From: Frank Warmerdam [mailto:warmerdam at pobox.com]
> Have you looked at FGS? It is the "natural" choice of a binaries
> for linux that will work with Chameleon and friends.
Yes, I've successfully installed Mapserver/Chameleon on a test system
without Apache or PHP pre-installed. My "working server" has Apache and
PHP5 installed as a module. I'm not clear on the implications when this
is the case - whether the FGS install will impinge on applications
running on the PHP5 module (including Plesk Control panel) for example.
I've asked about this on the Chameleon mailing list now, awaiting a
reply.
> /me scans for previous post.
> Was it "Problem installing gdal" where you say:
> Trying to do a make install of gdal-1.4.1 on Fedora. This
> seems to have a problem with Python.
> Make[1]: [gdal_wrap.o] Error 1
> Make: [py-module] Error 2
Yes
> First, you haven't given enough text around the failure to
> constructive answer. No doubt why I ignored it the first time around.
Apologies. It was a straight configure, with no options
> But also, what do you need python for if you want to use Chameleon?
> If you don't need it just configure "--without-python". There are
> lots of messy problems that can arise as you start adding
> languages and external libraries to gdal builds.
Good point! I've now tried the gdal configure --without-python and it
works fine, and is happy to play with the mapserver config.
Many thanks for your advice.
Alan Hale
Aberystwyth
Wales
No virus found in this outgoing message.
Checked by AVG Free Edition.
Version: 7.5.476 / Virus Database: 269.9.10/875 - Release Date:
27/06/2007 21:08
