transparency of rotated GIF files
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri Jun 29 15:17:41 EDT 2007
What version of GD are you using? With older versions there seems to be an issue in GD itself. I was
hoping perhaps that it was fixed on their end in 2.0.34 but I have not checked myself.
Steve
>>> On 6/28/2007 at 5:56 AM, in message
<20070628105600.b542dc2e at kmail.b3partners.nl>, Roy Braam
<roybraam at B3PARTNERS.NL> wrote:
> Hai,
> I've got a question about the transparency of rotated GIF files. Perhaps
> it's asked a many times but i can't find a answer on the internet.
> The layer:
> LAYER
> STATUS OFF
> METADATA
> "wms_title" "somelayer"
> END
> CONNECTIONTYPE postgis
> NAME "somelayer"
> CONNECTION "user=postgres password=xxxx dbname=xxxx host=xxxxx"
> DATA "the_geom from somelayer"
> #MAXSCALE 100000
> TYPE POINT
> DUMP TRUE
> TEMPLATE bla
> TOLERANCE 10
> TRANSPARENCY alpha
> CLASS
> EXPRESSION ('[s]'="B")
> NAME "Brug"
> STYLE
> ANGLE [road_direction]
> COLOR 0 0 255
> SYMBOL "bridge.gif"
> END
> END
> END
> If i don't rotate the image then the image is transparent but if i add the
> property angle [road_direction] the image rotates fine but isn't transparent
> any more. How can a i solv this problem?
> Tia,
> Roy
