AddPoints won't work
theresia freska
frezzz_54 at YAHOO.COM
Thu Mar 1 08:12:32 EST 2007
hi list,
i have a function to add points dynamically. it works on the A data, but not on the B data. yet i have copied the same code. this function works as user selects the nquery mode.
if (($_POST['mode']) == "nquery") {
do_the_function;
the strange thing is that when i eliminate the if condition, it works just fine. i don't know where i did the wrong code. can someone point that out for me? i use mapserver 4.8.3. i use this code to debug. thanks in advance.
if ($_POST['mode'] == "nquery") {
/*$inputLayer = $_POST['slcQlayer'];
$radius = abs($_POST['radius']);
if (!(in_array($inputLayer, $tesLayer))) {
echo "<script language='Javascript'>alert('Layer $inputLayer tidak aktif. Query tidak akan dilanjutkan.')</script>";
} else {
$nearby = nearbyResto($qpoint, $map, $radius, $inputLayer);
$arrRes = getInfo($inputLayer, $nearby);
$result_table = tabelResto($arrRes);*/
$conn = pg_connect("dbname=$database user=$user password=$password host=$host");
$m=0;
$res_layer = pg_query("select gid from point where kategori='Pasar'");
while($row_layer = pg_fetch_row($res_layer)) {
$arr_layer[$m] = $row_layer;
$m++;
for ($i=0;$i<count($arr_layer);$i++) {
$baris = $arr_layer[$i];
$res = pg_query("select kategori, x(the_geom), y(the_geom) from point where gid=$baris[0]");
$row = pg_fetch_row($res);
$arr[$i] = $row;
AddPoints($map, $arr);
Want to start your own business? Learn how on Yahoo! Small Business.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070301/12faefd3/attachment.html
