MapServer 4.10 with DSO PHP5
Daniel Morissette
dmorissette at MAPGEARS.COM
Thu Mar 1 09:48:32 EST 2007
That could be caused by conflicting versions of GD, i.e. Your PHP has
--with-gd which will probably trigger the use of its built-in copy of
GD, and your php_mapscript.so is built with the system GD.
I'd suggest that you try rebuilding your PHP using the system GD and see
if that helps. If GD is unstalled under /usr/local then use
--with-gd=/usr/local
Daniel
Guillaume Sueur wrote:
> Hi list,
> I was wondering if MapScript 4.10 could be build with PHP5 as Apache
> DSO. I've done several attempts, without success. The build goes fine,
> but invoking the draw method on a map object causes a segmentation fault.
> I've tried the "regex hack" on the php configure, to force php to be
> build with system regex.
> The option with-apxs on mapserver configure fires a message saying in
> can't work that way. I can accept that, but why are people saying it
> works fine for them on the net ?
> So, if you had a clue, and some configure options and workarounds, I
> would really appreciate.
> Here are my php configure options (the use of regex=system is forced in
> the configure script):
> './configure' '--prefix=/usr/local/apache2/'
> '--with-apxs2=/usr/local/apache2/bin/apxs'
> '--with-config-file-path=/usr/local/apache2/php' '--with-regex=system'
> '--with-jpeg-dir=/usr' '--with-png-dir=/usr' '--with-zlib' '--with-gd'
> '--with-freetype-dir=/usr/local/' '--enable-dbase' '--with-pdflib'
> '--enable-gd-native-ttf'
> Thanks
Daniel Morissette
http://www.mapgears.com/
