wms.jpl.nasa.gov renders on LINUX but not in the MS4W install
Andrew Parker
aparker1969 at YAHOO.COM
Fri Mar 2 14:32:14 EST 2007
I am trying to add the modis and global_mosaic layers from
http://wms.jpl.nasa.gov to the map in my MS4W install (on Windows XP and
Windows Server2003). WMS layers render from terraservice.net with no
problems. The code in the mapfile works with the LINUX test box.
Does anyone have a reason or solution? Be easy on me as I am new to
Mapserver. Below is my mapfile code.
Thanks in advances for any help.
Andrew.
# Start of map file
# Sample map file for a chameleon app.
NAME DEMO
STATUS ON
SIZE 400 300
SYMBOLSET ../etc/symbols.sym
EXTENT -109.1 31.26 -102.89 37.09
UNITS DD
PROJECTION
"init=epsg:4326"
END
SHAPEPATH "../data"
IMAGECOLOR 25 25 112
FONTSET ../etc/fonts.txt
TRANSPARENT FALSE
# IMAGETYPE - set to PNG24 in /congif/chameleon.xml
# Start of web interface definition
WEB
#MINSCALE 2000000
#MAXSCALE 50000000
# On Windows systems, /tmp and /tmp/ms_tmp/ should be created at the root
# of the drive where the .MAP file resides.
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
# LOG "/tmp/gmap.log"
METADATA
END
END
# Start of reference map
REFERENCE
IMAGE images/ref_msone.jpg
EXTENT -126.12 23.27 -66.14 50.15
STATUS ON
COLOR -1 -1 -1
OUTLINECOLOR 255 0 0
SIZE 120 90
END
# Start of legend
LEGEND
KEYSIZE 18 12
LABEL
TYPE BITMAP
SIZE MEDIUM
COLOR 0 0 89
END
STATUS ON
END
# Start of scalebar
SCALEBAR
IMAGECOLOR 255 255 255
LABEL
COLOR 0 0 0
SIZE SMALL
END
SIZE 150 5
COLOR 255 255 255
BACKGROUNDCOLOR 0 0 0
OUTLINECOLOR 0 0 0
UNITS Miles
INTERVALS 5
STATUS ON
END
QUERYMAP
STYLE HILITE
COLOR 255 0 0
END
# Symbol for drawing fat lines
SYMBOL
NAME "BigLine"
TYPE ELLIPSE
POINTS 1 1 END
END
# Symbol for drawing dashed lines
SYMBOL
NAME "DashedLine"
TYPE ELLIPSE
POINTS 1 1 END
STYLE 10 10 END
END
# Symbol for drawing spots
SYMBOL
NAME "Circle"
FILLED true
TYPE ellipse
POINTS 1 1 END
END
# Country layer
LAYER
NAME "Countries"
STATUS on
TYPE polygon
DATA "countries"
UNITS dd
PROJECTION
"init=epsg:4326"
END
CLASS
# A template defined at the class level is used to
# display the results for each reponse to a query. If a
# query results in N hits, then the template will be used
# N times. To be queriable a layer must specify a CLASS
# level template.
TEMPLATE "/ms4w/apps/msone/htdocs/msone_countries_query.html"
NAME "USA"
EXPRESSION ('[COUNTRY]' eq 'US')
STYLE
COLOR 238 232 170
END
END # end class
CLASS
# level template.
NAME "OTHER"
EXPRESSION ('[COUNTRY]' ne 'US')
STYLE
COLOR 205 190 112
END
END # end class
END # end layer
# Line layer for Country boundaries
LAYER
UNITS dd
PROJECTION
"init=epsg:4326"
END
NAME "Boundaries"
STATUS on
TYPE line
DATA "countries"
CLASS
STYLE
COLOR 0 0 0
END
END # end class
END # end layer
# USGS_topo
LAYER
NAME "Terraserver_DRG"
STATUS off
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://terraservice.net/OgcMap.ashx?";
METADATA
"wms_srs" "EPSG:4326"
"wms_title" "Digital Raster Graphic"
"wms_name" "DRG"
"wms_server_version" "1.1.1"
"wms_format" "image/jpeg"
"wms_layers" "drg"
"wms_group_title" "background"
END
PROJECTION
"init=epsg:4326"
END
END
# ******************** Orthophoto ********************
LAYER
NAME "TerraServer_Orthophoto"
STATUS off
TYPE RASTER
CONNECTIONTYPE WMS
METADATA
"wms_title" "Orthophoto"
"wms_name" "DOQ"
"wms_layers" "drg"
END
PROJECTION
"init=epsg:4326"
END
END
# ******************** Nexrad Radar ********************
LAYER
NAME Nexrad_RADAR
STATUS OFF
GROUP "Background"
TYPE RASTER
CONNECTIONTYPE WMS
CONNECTION "http://mesonet.agron.iastate.edu/cgi-bin/wms/nexrad/n0r.cgi?";
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_name" "nexrad-n0r-m45m"
"wms_style" ""
"wms_title" "NEXRAD"
END
END
# ******************** MODIS derived blue marble image ********************
LAYER
NAME Blue_Marble
STATUS on
PROJECTION
"init=epsg:4326"
END
TYPE RASTER
OFFSITE 0 0 0
CONNECTIONTYPE WMS
CONNECTION "http://wms.jpl.nasa.gov/wms.cgi?";
METADATA
"wms_name" "modis,global_mosaic"
"wms_styles" ""
"wms_title" "BlueMarble"
END
END
# State boundaries layer - polygon (for shading)
LAYER
NAME "states_poly"
DATA "statesp020"
UNITS dd
PROJECTION
"init=epsg:4326"
END
STATUS off
TYPE polygon
LABELCACHE on
LABELITEM "STATE"
CLASS
STYLE
# COLOR 238 232 170
END
END
END
# State boundaries layer - line (for fat boundary)
LAYER
NAME "states"
DATA "statesp020"
UNITS dd
PROJECTION
"init=epsg:4326"
END
STATUS off
TYPE line
LABELCACHE on
LABELITEM "STATE"
CLASS
NAME "State Line"
STYLE
SYMBOL "BigLine"
SIZE 2
COLOR 0 0 0
END
END
END
# Road layer - interstates only at large scale
LAYER
NAME "interstate1"
GROUP "roads"
DATA "roadtrl020"
STATUS off
TYPE line
UNITS dd
PROJECTION
"init=epsg:4326"
END
LABELCACHE on
LABELITEM "NAME"
CLASSITEM "FEATURE"
MINSCALE 7500001
CLASS
NAME "Interstate Hwy"
EXPRESSION /Limited Access*/
STYLE
SYMBOL "BigLine"
SIZE 1
COLOR 0 0 0
END
LABEL
TYPE truetype
FONT "arial"
SIZE 8
OUTLINECOLOR 255 255 255
COLOR 0 0 0
MINDISTANCE 200
POSITION auto
ANGLE auto
MINFEATURESIZE 50
END
END
END
# ROC Sites
LAYER
NAME "ROCsites"
STATUS off
UNITS dd
PROJECTION
"init=epsg:4326"
END
TYPE point
DATA "ROCsites"
MAXSCALE 1200000
LABELITEM "SITE_NAME"
CLASS
NAME "ROC Sites"
STYLE
SYMBOL "Circle"
SIZE 9
COLOR 255 127 0 #coral
END
LABEL
TYPE truetype # use truetype font
FONT "arialbd" # use arial bold
SIZE 7 # use 8 point size
COLOR 255 127 0 # color text coral
BACKGROUNDCOLOR 255 255 255 # render text on white bg
MINDISTANCE 50 # labels > 50 pixels apart
POSITION auto # center labels below feature
ANTIALIAS true # antialias the text
END # end label
END # end class
END # end layer
# ROC Monitoring Wells
LAYER
NAME "ROCmw"
STATUS off
UNITS dd
TYPE point
DATA "ROCmw"
LABELITEM "Well_Name" # labels use value in column "NAME"
LABELCACHE on
LABELMAXSCALE 1200000
MAXSCALE 1200000
CLASS
NAME "ROC MWs"
STYLE
SYMBOL "Circle"
SIZE 9
COLOR 0 0 205 #Medium Blue
END
LABEL
COLOR 0 0 205 # color text coral
END # end label
END # end class
END # end layer
END # Map File
