Problems with Mapserver4.10.1--GD--Fedora Core 6 (espanol - english)
Adriano Torres atorresma at UC.CL
Sat Mar 3 10:51:43 PST 2007
Gregor Mosheh escribió:
> I've had the worst time with Fedora, in that it's often missing header
> files. In the case of GD, it's missing the gd.h and other header files.
> Sigh.
> What I've resorted to in the past is to download the GD source for the GD
> version I have (rpm -qa | grep gd) and then manually install gd.h into
> /usr/include or wherever.
Hi everybody
Thanks Gregor for four answer... I tried to install manually but ./configure
doesn't work yet :(
The mapserver configure said: "configure: error: Could not find gd.h or
libgd.a/libgd.so in /usr/local. Make sure GD 2.0.16 or higher is compiled
before calling configure. You may also get this error if you didn't specify
the appropriate location for one of GD's dependencies (freetype, libpng,
libjpeg or libiconv)"
I have freetype, libpng, libjpeg and libiconv properly installed (I believe it):
# rpm -qa | grep gd
sysklogd-1.4.1-41.fc6
gd-2.0.33-10.fc6
gdb-6.5-15.fc6
gdbm-1.8.0-26.2.1
php-gd-5.1.6-3.4.fc6
gd-devel-2.0.33-10.fc6
gdm-2.16.5-1.fc6
libgdiplus-1.1.17-1.fc6
gdbm-devel-1.8.0-26.2.1
What mean that "You may also get this error if you didn't specify the
appropriate location for one of GD's dependencies"???  May the error be this?
I dont know what do :(
Thanks
Adriano
Saludos a la comunidad de habla hispana.
More information about the MapServer-users mailing list
