MapServer 4.10 with DSO PHP5 -> GD issues
Guillaume Sueur
guillaume.sueur at GEOSIGNAL.FR
Sun Mar 4 05:24:04 EST 2007
I've managed to make php-5.1.4-gd and gd-2.0.34 work together (php with
its own gd and mapserver with the system one)! I think there are
compatibilities issues depending on the version used with each. As GD is
updated AFTER php-gd, I think one could use a gd version newer than the
php one. but still no imageresize in the standard gd. Weird.
Daniel Morissette a écrit :
> Guillaume Sueur wrote:
>> One more thing : using the system gd library works well, but some gd
>> functions (imagerotate or imagelayereffect for example) requires php
>> to be build against embedded version of gd.
>> So, is there a way to build mapserver against php version of gd, or to
>> find the source of it to be able to build it as the system lib too ?
> I believe the source is under php/ext/gd, but I don't know if the PHP
> version of GD can be built as a standalone lib and used by external
> programs. You could try and let us know.
> BTW, GD has been brought back to life recently at http://libgd.org/
> "under the umbrella of PHP.net" so they are definitely aware of the PHP
> GD fork and there's hope that some of these new functions may be added
> to future releases (or may be in the dev version, 2.1.0 in CVS HEAD?).
> Daniel
