Does MapServer support WMS time series using polygon shapefiles?
Peter Shrock
thesl at YAHOO.COM
Fri Mar 9 13:03:34 EST 2007
Hello,all:
I am having difficulties to make WMS time series work.
I am using mapserver 4.10.0. I tested point data with time dimension, it
worked. I tested tiled polygons, it worked.
But I cannot get polygon shapefile work for time series WMS
I used identitical polygon shapefiles, one shapefile for one year. tile index
shapefile (index1.shp) was created using tile4ms.exe, and I verified the
contents of the file.
I tried two methods in order to make the WMS time series work. Both failed.
Could you please help me?
# Test method 1: everything in one layer object
LAYER
NAME "timemap"
TYPE RASTER
STATUS ON
METADATA
"wms_title" "timemap"
"wms_timeformat" "YYYYMMDD"
"wms_timeextent" "20021130/20061130"
"wms_timeitem" "DATETIME"
"wms_timedefault" "20021130"
"wms_srs" "EPSG:4326"
END
TILEINDEX "index1.shp"
TILEITEM "Location"
CLASSITEM "color_code"
CLASS
NAME "TYPE 1"
EXPRESSION ([color_code]==1)
COLOR 220 120 130
OUTLINECOLOR 150 150 150
END
CLASS
NAME "TYPE 2"
EXPRESSION ([color_code]==2)
COLOR 255 255 155
END
CLASS
NAME "TYPE 3"
EXPRESSION ([color_code]==0)
COLOR 200 200 200
OUTLINECOLOR 100 100 100
END
END # one layer object method
# Test method 2: seperate tileindex layer and data layer
LAYER
NAME "mylayer"
STATUS ON
TYPE RASTER
TILEINDEX "index1"
TILEITEM "Location"
PROJECTION
"init=epsg:4326"
END
METADATA
"wms_title" "mylayer"
"wms_srs" "epsg:4326"
"wms_timedefault" "20030210"
END
SIZEUNITS PIXELS
CLASS
NAME "TYPE 1"
COLOR 220 120 130
END
CLASS
NAME "TYPE 2"
COLOR 255 255 155
END
CLASS
NAME "TYPE 3"
COLOR 200 200 200
END
END
LAYER
NAME "tidx"
TYPE TILEINDEX
STATUS ON
DATA index1
FILTERITEM 'DATETIME'
FILTER '%DATETIME%'
END # tile layer
The error message is:
msDrawMap(): Image handling error. Failed to draw layer named 'timemap'.
msDrawRaster(): Image handling error. Unrecognized or unsupported image format
drawEPP(): Image handling error. EPPL7 support is not available.
The error message does not seem helpful.
Thanks
Peter
____________________________________________________________________________________
Bored stiff? Loosen up...
Download and play hundreds of games for free on Yahoo! Games.
http://games.yahoo.com/games/front
