expression
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Mon Mar 12 15:22:01 EDT 2007
I've got a feeling that ain't the problem. You need the quotes around
the attribute name. I wonder if
the special character is causing a problem. Leonardo, can you share the
shapefile?
Steve
>>> On 3/12/2007 at 9:14 AM, in message
<45F56030.2010607 at swoodbridge.com>, Stephen
Woodbridge <woodbri at SWOODBRIDGE.COM> wrote:
> Leonardo Olivieri wrote:
>> Hello,
>> I Have installed mapserver phpmapscript on linux.
>> In the shapefile using ArcMap I haved a column COD_PIANO and a
value is =
> attività
>> COD_PIANO
>> attività
>> In the mapfile on linux, I have the expression
>> EXPRESSION ('[COD_PIANO]' eq 'attività')
> Try:
> EXPRESSION ([COD_PIANO] eq 'attività')
>> but this expression don't work
>> Any hints?
>> Thanks in advanced.
>> Leonardo
