Antwort: [UMN_MAPSERVER-USERS] Display Lines as Points
Benedikt Rothe
umn-ms at HYDROTEC.DE
Thu Mar 15 03:35:08 EDT 2007
Hi
Maybe you could use an PL/SQL-Function, which converts the lines into
multipoints.
create or replace function Line2Point(aLine mdsys.sdo_geometry) return
mdsys.sdo_geometry is
dims integer;
begin
if (aLine is null) then
return null;
end if;
if (aLine.SDO_ELEM_INFO is null or aLine.SDO_ORDINATES is null) then
return null;
end if;
dims := aLine.SDO_GTYPE / 1000;
return MDSYS.SDO_GEOMETRY(
dims*1000+5, -- SDO_GTYPE: MULTIPOINT,
aLine.SDO_SRID,
NULL, -- No Singe-Point
-- SDO_STARTING_OFFSET,SDO_ETYPE: Point type
,SDO_INTERPRETATION: Point cluster with n points.
MDSYS.SDO_ELEM_INFO_ARRAY(1,2,aLine.SDO_ORDINATES.
Count / dims),
aLine.SDO_ORDINATES); -- Ticks don't change
end Line2Point;
create or replace view XStream as Select Line2Point(shape) shape,
name,nummer from Streams;
Than use XStream in the Layer of the Mapserver-Map-File.
Maybe you must dig a little bit in the SDO-Documentation to find correct
settings for ELEM_INFO_ARRAY.
Should be something like this.
Benedikt Rothe
UMN MapServer Users List <MAPSERVER-USERS at LISTS.UMN.EDU> schrieb am
14.03.2007 16:17:48:
> Hi Folks!
> We have a rather tricky problem and maybe someone out there knows a
> solution.
> We have a layer of rivers, divided in 500m Segments, stored in an
> Oracle Spatial DB.
> Each segment is a simple line with a starting point and an end point,
> but they shall not be displayed a slines, but rather as points.
> What we want is simnply to represent every segment by its starting point
> only.
> Is that possible?
> Walter
> LFRZ
> A-1200 Wien, Dresdner Strasse 89
> Tel: ++43(1)33 176/421
> Fax: ++43(1)33 176/999
> Email: walter.pleyer at lfrz.at
> WWW: http://www.lfrz.at
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070315/8217a752/attachment.html
