fastcgi under Mapserver MS4W environment
John Mitchell
mitchelljj98 at GMAIL.COM
Mon Mar 19 07:37:37 EDT 2007
Hi,I would like to use fastcgi for the MS4W environment, and I have explored
the following link:
http://mapserver.gis.umn.edu/docs/howto/fastcgi which says the following:
<http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents> FastCGI
on Win32<http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents>
MS4W
Users <http://mapserver.gis.umn.edu/docs/howto/fastcgi/#table-of-contents>
MS4W (MapServer for Windows) <http://www.maptools.org/ms4w/> >= version
2.2.2 contains MapServer compiled with FastCGI support. However MS4W does
not contain the required Apache module mod_fastcgi, because the module must
be compiled to work with the Apache 2.2.x series (MS4W contains Apache 2.2.4).
If you compile this please contribute it back to the MS4W mailing
list<http://lists.maptools.org/mailman/listinfo/ms4w-users>
It appears from above that I need module mod_fastcgi compiled. Has anyone
done this?
Is fast-cgi running within mapserver when setup in the following way: MS4W
setup with latest FWTools bin content copied into MS4W apache\cgi-bin. I run
mapserv -v and it says fastcgi. Is their anything else that I have to do?
Thanks,
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070319/16bd7aa6/attachment.html
