merc projection changing lat_0 has no effect
Ed McNierney
ed at TOPOZONE.COM
Mon Mar 19 20:40:05 EDT 2007
Ryan -
Can you post the MAP file or the PROJECTION block you are using for the
modified projection?
- Ed
Ed McNierney
TopoZone.com
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
Behalf Of Ryan Ollerenshaw
Sent: Monday, March 19, 2007 6:36 PM
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: [UMN_MAPSERVER-USERS] merc projection changing lat_0 has no
effect
I am trying to reproject my map which is in the geographic projection
4326 to a Mercator projection, which works, however, when i change
lat_0 to anything it has no effect. I can change lon_0 and the images
shifts appropriatly but for some reason lat_0 has no effect.
-Thank you.
