NaN results for itemquery with Dbox
william paul
williampaul28 at YAHOO.COM
Tue Mar 20 15:07:39 EDT 2007
Hi:
I am using Dbox and the example provided by Rich Greenwood, to map the results from a database query. I have modified the script so you can change the queryfile, qitem and qstring. The script works OK on 1 layer, but for others I get NaN. Before to map the results I test ( alert(qlayer, qitem, qstring)) to see if the queryfile, qitem and qstring are correct. Even though I have the core ct names for each one I still get NaN results
What could be the problem?
script from the database query results
<script type="text/javascript" language="javascript">
var qlayer = "anyQlayer";
var qitem = "anyQitem";
function map(qstring)
opener.itemQueryModified(qstring, qitem, qlayer);
window.close();
opener.focus();
</script>
modified itemQuery script
ms.itemqueryoptions = "&mapext=shapes&savequery=true&";
function itemQueryModified(qstring, qitem, qlayer)
//ms.setLayer(qlayer, true);
var uri = ms.mapserver + '?map=' + ms.mapfile + "&layers=" + ms.getLayers("+") + "&mapsize=" + ms.width + "+" + ms.height;
uri += ms.itemqueryoptions;
uri += '&mode=itemquery'
uri += '&qlayer=' + qlayer;
uri += '&qitem=' + qitem;
uri += '&qstring=' + qstring;
var response = get_content(uri);
var tokens = response.split(',');
alert(qstring + qitem + qlayer + ", " + Number(tokens[1]), Number(tokens[2]), Number(tokens[3]), Number(tokens[4]));
ms.setExtent(Number(tokens[1]), Number(tokens[2]), Number(tokens[3]), Number(tokens[4]));
main.setImage(tokens[5]);
ms.savedqueryfile=tokens[6];
domouseclick('pan');
Need Mail bonding?
Go to the Yahoo! Mail Q&A for great tips from Yahoo! Answers users.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070320/c1dd3a31/attachment.html
