NaN results for itemquery with Dbox
william paul
williampaul28 at YAHOO.COM
Thu Mar 22 10:24:55 EDT 2007
As usually: Thank you Rich
The strange part is that I have a match in my database, but I still get the NaN results. If I use the query tool from mapserver I get the proper results.
The only difference is that when I send text (the qstring is a text) from the database to mapserver I get the proper results. When I send numbers (the qstring is a number) I get NaN results. Do you think it could be related to the type of the data used for query?
I will make other tests
William
Richard Greenwood <richard.greenwood at gmail.com> wrote:
On 3/20/07, william paul wrote:
> Hi:
> I am using Dbox and the example provided by Rich Greenwood, to map the
> results from a database query. I have modified the script so you can change
> the queryfile, qitem and qstring. The script works OK on 1 layer, but for
> others I get NaN. Before to map the results I test ( alert(qlayer, qitem,
> qstring)) to see if the queryfile, qitem and qstring are correct. Even
> though I have the core ct names for each one I still get NaN results
> What could be the problem?
> script from the database query results
> var qlayer = "anyQlayer";
> var qitem = "anyQitem";
> function map(qstring)
> opener.itemQueryModified(qstring, qitem, qlayer);
> window.close();
> opener.focus();
> modified itemQuery script
> ms.itemqueryoptions = "&mapext=shapes&savequery=true&";
> function itemQueryModified(qstring, qitem, qlayer)
> //ms.setLayer(qlayer, true);
> var uri = ms.mapserver + '?map=' + ms.mapfile + "&layers=" +
> ms.getLayers("+") + "&mapsize=" + ms.width + "+" + ms.height;
> uri += ms.itemqueryoptions;
> uri += '&mode=itemquery'
> uri += '&qlayer=' + qlayer;
> uri += '&qitem=' + qitem;
> uri += '&qstring=' + qstring;
> var response = get_content(uri);
> var tokens = response.split(',');
> alert(qstring + qitem + qlayer + ", " + Number(tokens[1]),
> Number(tokens[2]), Number(tokens[3]), Number(tokens[4]));
> ms.setExtent(Number(tokens[1]), Number(tokens[2]), Number(tokens[3]),
> Number(tokens[4]));
> main.setImage(tokens[5]);
> ms.savedqueryfile=tokens[6];
> domouseclick('pan');
You probably didn't get a match in your database. NaN means "Not a
Number". MapServer did not return an extent for the selection because
it could not find anything, and so your browser was not able to
convert the tokens 1-4 into numbers.
I try to catch that and tell the user something like "no results found".
Rich
Richard Greenwood
www.greenwoodmap.com
It's here! Your new message!
Get new email alerts with the free Yahoo! Toolbar.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070322/de7aacd4/attachment.html
