processlegendtemplate()
Harri Kiiskinen
harri.kiiskinen at UTU.FI
Fri Mar 23 09:16:12 EDT 2007
Hello all,
I'm having a problem with the processlegendtemplate(array) in PHP/Mapcript.
According to the documentation, it should accept a similar parameter array
as processtemplate(arraý, bool). However, it seems, that while
processtemplate() does do the replacements from the array,
processlegendtemplate() does not. Example:
In php:
$template_params["program"]=$_SERVER['PHP_SELF'];
echo $map->processtemplate($template_params,MS_TRUE);
$ltemplate_params["lprogram"]=$_SERVER['PHP_SELF'];
echo $map->processlegendtemplate($ltemplate_params);
In template_map:
<form method="post" action="[program]">
In template_legend:
[leg_header_html]
<form method="post" action="[lprogram]">
[/leg_header_html]
In resulting html, for the map template:
<form method="post" action="/~harri/nemi/nemidb/map_general.php">
and for the legend template:
Might be I have misunderstood the documentation, but at least the
PHP/Mapscript documentation indicates, that this should work.
Greetings,
Harri K.
