Mapscript crashing Tomcat --> [Panic]
Frank Warmerdam
warmerdam at POBOX.COM
Wed Mar 28 16:53:59 EDT 2007
Rodrigo Del C. Andrade wrote:
> Greetings. dear list.
> We are experiencing some troubling difficulties developing an
> application with mapscript on a Java web based environment with tomcat.
> Here is the deal: while using the app (not nearly done, but
> functional enough at this stage) when one tries to zoom (in or out) or
> pan the map more than a few times, Tomcat often will go down screaming
> and the JVM just gives up on life.
> I know this is probably not the right or best place to ask about it,
> but it seems to be caused by the interaction of mapscript and the GD
> library.
> Here is the JVM output short version (long version is attached
> at the bottom):
> Any ideas? Full JVM error log is at the bottom. I am ready to give in
> more info if needed.
> Thanks in advance;
> Stack: [0xb0203000,0xb0284000), sp=0xb0279ed4, free space=475k
> Native frames: (J=compiled Java code, j=interpreted, Vv=VM code,
> C=native code)
> C [libgd.so.2+0x8182]
> C [libgd.so.2+0x9a16] gdImageLine+0x4a6
> C [libmapscript.so+0xad355]
> C [libmapscript.so+0xb310e] msDrawLineSymbolGD+0xe7e
> C [libmapscript.so+0xa75fb] msDrawLineSymbol+0x8b
> C [libmapscript.so+0xa9cb2] msDrawShape+0x17e2
> C [libmapscript.so+0xaa6d8] msDrawVectorLayer+0x398
> C [libmapscript.so+0xaa97a] msDrawLayer+0xaa
> C [libmapscript.so+0xaba67] msDrawMap+0x6a7
> C [libmapscript.so+0x552b5]
Rodrigo,
I'd suggesting seeing if you can reproduce this without Java involved. I
suspect there is some sort of memory error in msDrawLineSymbolGD() (possibly
the infamous antialiasing bug?).
Capture your map configuration into a map file, and run the map through
shp2img or mapserv with the appropriate layers turned on, and similar
view configuration *and* run it under "valgrind" to quickly highly
memory corruption as soon as it happens.
If you can reproduce it this way,then you have something you can file
as a bug report.
MapServer is not bug free, and it is important to be able to narrow
down bugs without too much extraneous stuff.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
