issue with classitem and tileindex...
Stephen Woodbridge
woodbri at SWOODBRIDGE.COM
Thu Mar 29 16:33:30 EDT 2007
John,
In shapefiles attribute are all upper case. try:
classitem 'CFCC'
-Steve W
John Cole wrote:
> I have a couple of county shapefiles where I've created a tileindex using
> tile4ms. When I render these with MS, things work fine until I set the
> classitem, and then it can't find the classitem column on the shapefile (in
> this case 'cfcc').
> Is there something special you have to do to use a class item or label item
> with a tileindex?
> Thanks,
> John
