issue with classitem and tileindex...
Brent Fraser
bfraser at GEOANALYTIC.COM
Thu Mar 29 18:33:02 EDT 2007
John,
Make sure all the tile shapefiles have the same attributes
(name, type, and order). Other than that, I'm tempted to
fire up the debugger...
Searching the email archive shows some posts about Tiger
data working with a tileindex, and classes with expressions,
so it should work (I know, that doesn't help much).
Brent Fraser
GeoAnalytic Inc.
Calgary, Alberta
----- Original Message -----
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, March 29, 2007 3:21 PM
Subject: Re: [UMN_MAPSERVER-USERS] issue with classitem and
tileindex...
> Brent,
> Well, I didn't know about the 'newer' method. I got it
working similar to
> the 'old' one but it still doesn't recognize the 'CFCC'
column when I add
> the class item.
> Thanks,
> John
> Brent Fraser wrote:
> > John,
> > You could try the newer (and more flexible?)
"two-layer"
> > style of tileindex specification:
> > LAYER
> > NAME "lpy_idx_lyr"
> > TYPE TILEINDEX
> > DATA "lpy_idx"
> > END
> > LAYER
> > NAME "landmark_polys"
> > GROUP "bound"
> > TILEINDEX "lpy_idx_lyr" # this points to the above
layer
> > METADATA
> > "wms_title" "landmark_polys"
> > "wms_group_title" "landmark"
> > END
> > PROJECTION
> > "init=epsg:4326"
> > END
> > STATUS ON
> > CLASSITEM "CFCC"
> > CLASS
> > EXPRESSION "D82"
> > NAME 'Cemetary'
> > MAXSCALE 250000
> > STYLE
> > COLOR 209 208 204
> > END
> > END
> > END
> > I haven't tested this, so it may not work. The trick is
to
> > tell Mapserver the CLASS is to be applied to the files
> > pointed to by the tileindex, not the tile index itself
(I'm
> > sure it doesn't have an attributed named "CFCC").
> > Steve Woodbridge may have some insight into this, since
it's
> > tiled vectors; I've only done tiled raster....
> > Brent Fraser
> > GeoAnalytic Inc.
> > Calgary, Alberta
> > From: "John Cole" <john.cole at UAI.COM>
> > Sent: Thursday, March 29, 2007 2:04 PM
and
> > tileindex...
> >> Steve,
> >> Thanks for the quick reply, unfortunately I had
already
> > tried that :-(
> >> msDBFGetItemIndex(): DBASE file error. Item 'CFCC' not
> > found.
> >> Is there anything else that could be wrong?
> >> Here is my layer:
> >> LAYER
> >> GROUP "bound"
> >> TILEINDEX "lpy_idx"
> >> METADATA
> >> END
> >> PROJECTION
> >> "init=epsg:4326"
> >> END
> >> STATUS ON
> >> CLASSITEM "CFCC"
> >> TYPE POLYGON
> >> CLASS
> >> EXPRESSION "D82"
> >> NAME 'Cemetary'
> >> MAXSCALE 250000
> >> STYLE
> >> COLOR 209 208 204
> >> END
> >> END
> >> END
> >> We are using the current version of MS4W.
> >> Thanks,
> >> John
> >> Stephen Woodbridge wrote:
> >> > John,
> >> > In shapefiles attribute are all upper case. try:
> >> > classitem 'CFCC'
> >> > -Steve W
> >> > John Cole wrote:
> >> >> I have a couple of county shapefiles where I've
created
> > a tileindex using
> >> >> tile4ms. When I render these with MS, things work
fine
> > until I set the
> >> >> classitem, and then it can't find the classitem
column
> > on the shapefile
> >> >> (in
> >> >> this case 'cfcc').
> >> >> Is there something special you have to do to use a
> > class item or label
> >> >> item
> >> >> with a tileindex?
> >> >> Thanks,
> >> >> John
> >> View this message in context:
http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9741591
> >> Sent from the Mapserver - User mailing list archive at
> > Nabble.com.
http://www.nabble.com/issue-with-classitem-and-tileindex...-tf3488200.html#a9742947
Nabble.com.
