WCS from multiple netCDF returning only background image
Norman Barker
nbarker at ITTVIS.COM
Fri Mar 30 12:58:20 EDT 2007
Hi Frank, all,
I raised this as a bug report about 18 months or so ago, and put in a proposed fix, and it was put into the main code with a bit of twist, and I noticed that it didn't fix the problem with my data, thinking it was just a problem with my dataset I just continue to patch MapServer. It might be the same problem you are seeing.
(Must add this isn't a criticism, I am not a c++ programmer, and I could never write anything as fast as mapserver, just trying to help :-) ).
Can you try this in mapresample.c (Fixed msSimpleRasterResample() so that if in raw mode it loops through all the available bands) and see if it works (it is probably horribly inefficient)
/* msSimpleRasterResample() */
static int
msSimpleRasterResampler( imageObj *psSrcImage, colorObj offsite,
imageObj *psDstImage, int *panCMap,
SimpleTransformer pfnTransform, void *pCBData,
int debug )
double *x, *y;
int nDstX, nDstY;
int *panSuccess;
int nDstXSize = psDstImage->width;
int nDstYSize = psDstImage->height;
int nSrcXSize = psSrcImage->width;
int nSrcYSize = psSrcImage->height;
int nFailedPoints = 0, nSetPoints = 0;
gdImagePtr srcImg, dstImg;
srcImg = psSrcImage->img.gd;
dstImg = psDstImage->img.gd;
x = (double *) malloc( sizeof(double) * nDstXSize );
y = (double *) malloc( sizeof(double) * nDstXSize );
panSuccess = (int *) malloc( sizeof(int) * nDstXSize );
int band;
for (band =0; band < psSrcImage->format->bands; band++)
for( nDstY = 0; nDstY < nDstYSize; nDstY++ )
for( nDstX = 0; nDstX < nDstXSize; nDstX++ )
x[nDstX] = nDstX + 0.5;
y[nDstX] = nDstY + 0.5;
pfnTransform( pCBData, nDstXSize, x, y, panSuccess );
int nSrcX, nSrcY;
int nValue;
if( !panSuccess[nDstX] )
nFailedPoints++;
continue;
nSrcX = (int) x[nDstX];
nSrcY = (int) y[nDstX];
* We test the original floating point values to
* avoid errors related to asymmetric rounding around zero.
if( x[nDstX] < 0.0 || y[nDstX] < 0.0
|| nSrcX >= nSrcXSize || nSrcY >= nSrcYSize )
continue;
if( MS_RENDERER_GD(psSrcImage->format) )
if( !gdImageTrueColor(psSrcImage->img.gd) )
nValue = panCMap[srcImg->pixels[nSrcY][nSrcX]];
if( nValue == -1 )
continue;
nSetPoints++;
dstImg->pixels[nDstY][nDstX] = nValue;
else
int nValue = srcImg->tpixels[nSrcY][nSrcX];
int gd_alpha = gdTrueColorGetAlpha(nValue);
if( gd_alpha == 0 )
nSetPoints++;
dstImg->tpixels[nDstY][nDstX] = nValue;
else if( gd_alpha == 127 )
/* overlay is transparent, do nothing */;
else
nSetPoints++;
gdAlphaBlend( dstImg->tpixels[nDstY][nDstX],
nValue );
else if( MS_RENDERER_RAWDATA(psSrcImage->format) )
if( psSrcImage->format->imagemode == MS_IMAGEMODE_INT16 )
int nValue;
nValue = psSrcImage->img.raw_16bit[
nSrcX + nSrcY * psSrcImage->width + band*psSrcImage->width*psSrcImage->height];
if( nValue == offsite.red )
continue;
nSetPoints++;
psDstImage->img.raw_16bit[
nDstX + nDstY * psDstImage->width + band*psDstImage->width*psDstImage->height] = nValue;
else if( psSrcImage->format->imagemode == MS_IMAGEMODE_FLOAT32)
float fValue;
fValue = psSrcImage->img.raw_float[
if( fValue == offsite.red )
continue;
nSetPoints++;
psDstImage->img.raw_float[
nDstX + nDstY * psDstImage->width + band*psDstImage->width*psDstImage->height] = fValue;
else if( psSrcImage->format->imagemode == MS_IMAGEMODE_BYTE)
int nValue;
nValue = psSrcImage->img.raw_byte[
continue;
nSetPoints++;
psDstImage->img.raw_byte[nDstX + nDstY * psDstImage->width + band*psDstImage->width*psDstImage->height]
= (unsigned char) nValue;
else
assert( 0 );
free( panSuccess );
free( x );
free( y );
/* Some debugging output. */
if( nFailedPoints > 0 && debug )
char szMsg[256];
sprintf( szMsg,
"msSimpleRasterResampler: "
"%d failed to transform, %d actually set.\n",
nFailedPoints, nSetPoints );
msDebug( szMsg );
return 0;
-----Original Message-----
From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Frank Warmerdam
Sent: 29 March 2007 18:17
To: MAPSERVER-USERS at LISTS.UMN.EDU
Subject: Re: [UMN_MAPSERVER-USERS] WCS from multiple netCDF returning only background image
Jérôme Martin wrote:
> In fact the resolution pixel X must be the same as the resolution pixel
> Y, to do not strech on one axe the data.
Ed / Jérôme,
This is not expected behavior and if it persists in MapServer 4.10.1 and/or
CVS-head I'd appreciate a bug report.
One thing that is different when the aspect ratio is non-square is that
MapServer goes through more general resampling code (similar to when
reprojection is taking place), so if there are problems with the
coordinate system definitions on layers or the WCS request things might
fail.
Best regards,
and watch the world go round - Rush | President OSGeo, http://osgeo.org
