map extent
boice tomlin
boice at RUNSKIP.COM
Fri Mar 30 21:53:22 EDT 2007
Hello,
I have a few different shape files at different resolutions that I
want to load based on the extent of the map the user is viewing.
So if they are viewing the entire country for instance I want to load
in my low resolution data set.
The problem I'm having is that if a user zooms in on the map I have
to create the map object using the map file which specifies which
shapefile I am using, then use phpmapscript to zoom in, and then
retrieve the extent using phpmapscript functions. This obviously
doesn't help me load in the appropriate shapefile because I have to
create the map object in order to do any of the previous steps. A
bit of a paradox - load in the shapefile only to find out that I
might have wanted to use a different shapefile...
So the short question is how can I zoom in and get the extent before
loading the shapefile?
thanks,
boice
Run Skip
http://runskip.com/
boice tomlin
boice at runskip.com
503-528-6204
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070330/4932723f/attachment.html
