Change of Data Source changes Mapserver behavior
Matt Pettis
matt.pettis at THOMSON.COM
Thu May 3 19:59:38 PDT 2007
The map file at the end of this post is used by me to create a
client-side image map. When I call this map file using a data source of
.shp files (which happens when SHAPEPATH and the 'NAME "counties"' lines
are uncommented), I get the proper result back to the calling webpage.
When those lines are commented out and I instead use the lines that
begin:
CONNECTION ...
CONNECTIONTYPE ...
DATA ...
to retrieve the same date from a POSTGIS/POSTGRESQL database, I don't
get the right results. The following is a snippet of what I do get
returned:
Content-type: text/html
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 4.10.0 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
OUTPUT=WBMP OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ
SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=THREADS SUPPORTS=GEOS INPUT=JPEG
INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE DEBUG=MSDEBUG -->
<BODY BGCOLOR="#FFFFFF">
</BODY></HTML>
Can anybody answer why the behavior changes when all i do is change the
datasource? the shapefile and the table are the same (well, except for
whatever changes when I use the postgis tools to load the shapefile into
the Postgresql table, which should be only data format). Does anybody
know how to fix/work around this?
Thanks!
Matt
=== map.map ===
MAP
IMAGETYPE PNG
EXTENT 189783.546875 4810309 761653.5625 5472346.5
SIZE 680 510
SHAPEPATH "C:\ms4w\gisvote\data\shp"
IMAGECOLOR 255 255 255
WEB
# HEADER "imgmap-th.htm"
# FOOTER "imgmap-tf.htm"
# TEMPLATE "imgmap-t.htm"
IMAGEPATH "C:\ms4w\Apache\htdocs\tmp\"
IMAGEURL "/tmp/"
END
QUERYMAP
STATUS ON
STYLE NORMAL
END
LAYER
NAME "counties"
### this is pulling straight from the .shp files
DATA "counties"
### or...
### this does not behave like calling info from shape files... i don't
know why yet
### when using this, probably don't need the SHAPEPATH setting.
# CONNECTION "user=postgres dbname=postgis password=4theluv"
# CONNECTIONTYPE POSTGIS
# DATA "the_geom from (select * from shp_counties) as foo using
unique the_geom using SRID=-1"
STATUS DEFAULT
TYPE POLYGON
CLASS
NAME "county_class"
STYLE
COLOR 232 232 232
OUTLINECOLOR 32 32 32
END
END
END
END
It is from the wellspring of our despair and the places that we are
broken that we come to repair the world.
-- Murray Waas
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070503/19c1998b/attachment.htm>
More information about the MapServer-users
