Problems with libgd
Umberto Nicoletti
umberto.nicoletti at GMAIL.COM
Wed May 9 11:43:17 EDT 2007
What about the hs_errorlog file which is generated by Java when such
errors occur?
Please tell os and mapserver version, configure (build) options and,
that goes by itself, what you were doing when IT happened ;-)
Umberto
On 5/9/07, Frederico Lucca <fredlucca at gmail.com> wrote:
> Umberto,
> I'm using exactly the new one 2.0.34.
> Thanks,
> Fred
> On 5/9/07, Umberto Nicoletti < umberto.nicoletti at gmail.com> wrote:
> > Please tell the gd version you are using and report the header of
> > hs_error log. Gd versions before the very recent 2.0.34 have a number
> > of known bugs that could crash mapserver, but none (if I recall
> > correctly) on gdImageSetPixel.
> > Umberto
> > On 5/9/07, Frederico Lucca < fredlucca at gmail.com> wrote:
> > > Hello list,
> > > I'm having trouble to add pixmap symbols to my map.
> > > I'm using java mapscript and my tomcat broke with a problem in:
> > > libgd.so.2 - gdImageSetPixel
> > > What is happend? I need some help with this, thanks in advance.
> > > Fred
> > > "Everything under the sun is in tune
> > > But the sun is eclipsed by the moon"
