Problems with Mapserv and ArcSDE layer
Ivano Picco
ivano.picco at AQUPI.TK
Tue May 15 08:27:05 PDT 2007
Hi all!,
In the last days I made some performance and reliability tests on mapserv using CGI or
FastCGI on Apache or Lighttpd and connection from Oracle (native and OGR) or ArcSDE.
I've found a problem on Oracle native connection with FastCGI related to the memory leak
bug (1662) and on ArcSDE with CGI but I don't found anything about this second on ml or
trac.
This is the problem:
Using a layer defined as this:
LAYER
NAME "CTR-SDE"
STATUS ON
DEBUG ON
DATA "ctr_sde.comuni,SHAPE"
TYPE POLYGON
CONNECTIONTYPE SDE
CONNECTION "myserv,port:5153,esri_sde,sde,sde"
PROCESSING "CLOSE_CONNECTION=DEFER"
TEMPLATE "template.html"
METADATA
"WMS_SRS" "EPSG:32632"
"WMS_NAME" "Comuni_SDE"
"WMS_TITLE" "Comuni_SDE"
"WMS_ABSTRACT" "Comuni SDE"
END
CLASS
STYLE
OUTLINECOLOR 0 0 0
ANTIALIAS TRUE
END
END
END
and after 5 minutes long stress test with 16 contemporary connection on mapserv with this
URL :
http://mywebserv/cgi-bin/mapserv?VERSION=1.1.1&REQUEST=GetMap&WIDTH=550&HEIGHT=400&FORMAT=image/png&BBOX=225917.72,4878835.47,600524.92,5151277.07&TRANSPARENT=TRUE&BGCOLOR=0xFFFFFF&SRS=EPSG:32632&SERVICENAME=OGC:WMS&STYLES=&LAYERS=CTR-SDE
I see many cgi processes in memory. These processes still remain until web server restart.
This doesn't happen using both Oracle connection type and the same stress test .
What do I do wrong?
Thanks,
sorry for my english,
Ivano
P.S. this is the output from mapserv -v:
MapServer version 4.10.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=FREETYPE
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
SUPPORTS=GEOS INPUT=EPPL7 INPUT=SDE INPUT=ORACLESPATIAL INPUT=OGR
INPUT=GDAL INPUT=SHAPEFILE
More information about the MapServer-users
