AW: [UMN_MAPSERVER-USERS] Mapserver handling BBox in different coordinate systems
Milo van der Linden mlinden at ZEELANDNET.NL
Tue May 15 12:52:48 PDT 2007
Hello Arnd,
the @ is an error, my excuses. It indeed needs to be a & sign.
The reason you get a white background seems to be that the standard bbox
for EPSG:4326 is either undefined, or invalid. That is what I am trying
to find out.
Arnd Wippermann schreef:
> Hello Milo,
> botk links delivers the same map image. When I change the @ in the
> link, only for EPSG:28992 I get the map image. For EPSG:4326 I get
> only the credits and a white background.
> What's the meaning of the @ in the links?
> When I call your server with my Openlayers WMS client for both EPSGs,
> there is also no problem.
> Mit freundlichen Grüssen
> Arnd Wippermann
> http://gis.ibbeck.de/ginfo/ <BLOCKED::http://gis.ibbeck.de/ginfo/>
> *Von:* UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU]
> *Im Auftrag von *Milo van der Linden
> *Gesendet:* Dienstag, 15. Mai 2007 16:47
> *An:* MAPSERVER-USERS at LISTS.UMN.EDU
> *Betreff:* [UMN_MAPSERVER-USERS] Mapserver handling BBox in different
> coordinate systems
> Hello list,
> I have a mapserver running as WMS and WFS server that supports 2
> coordinate systems:
> Dutch RD stelsel (EPSG:28992)  and WGS84 (EPSG: 4326)
> When I call the Mapserver with the EPSG set at 28992, the map shows up
> correct. When I call it with EPSG set at 4326, I get nothing but a
> blank map.
> This connection works:
> http://webservice.nieuwekaart.nl/cgi-bin/nkn?request=getmap&version=11.0@SRS=epsg:28992&Layers=nk_water,nk_groen,nk_landbouw,nk_recreatie,nk_voorziening,nk_gemengd,nk_wonen,nk_verkeer,nk_lijn,nk_plan
> This connection fails in that it shows only a white map..
> http://webservice.nieuwekaart.nl/cgi-bin/nkn?request=getmap&version=11.0@SRS=epsg:4326&Layers=nk_water,nk_groen,nk_landbouw,nk_recreatie,nk_voorziening,nk_gemengd,nk_wonen,nk_verkeer,nk_lijn,nk_plan
> It seems that when the map recieves boundingbox coordinates in Lat/lon
> wgs84 (which are way out of the RD Stelsel bound) it returns this area
> which is just a background (white) because no data is present in RD
> Stelsel at that location.
> My Question is;
> What options are available to me?
> - Copying the mapserv executable and referencing another mapfile that
> is completely wgs84?
> - Altering the current mapfile so it can recieve boundingbox
> coordinates in wgs84 AND RD Stelsel? How?
> Any suggestions are welcome
> Kind regards,
> Milo van der Linden
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070515/a2183225/attachment-0001.htm>
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070515/a2183225/attachment-0001.sig>
More information about the MapServer-users mailing list
