SIZE in percentages?
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Wed May 16 15:12:39 EDT 2007
Using symbol scales and then tweaking the resolution parameter is the built in way to do this.
Symbol scale set the scale at which a symbol or label is exactly SIZE pixels tall. The resolution
parameter (map level) affects the way in which scales are computed. The default is 72 pixels
per inch which works ok for monitors but is too low for print, where value of 300 or higher might
work better.
Steve
>>> On 5/16/2007 at 1:49 PM, in message
<d9824c396b0ffd49c957786adb749aff at 83.87.144.191>, "Bart van den Eijnden
(OSGIS)" <bartvde at OSGIS.NL> wrote:
> Hi list,
> we've got a problem with labels getting too small in a PDF print (not using
> Mapserver's PDF output btw). The WMS image requested for the PDF print is
> approximately 2000 x 1500 pixels, and then squeezed into an A4 PDF to get an
> appropriate resolution for prints.
> But since labels are 9 pixels only (the same MAP file is also used for a
> webmapping application with a 600 x 400 map), they end up being too small.
> Is there an option to have something like SIZEUNITS percentage, and then use
> for instance a percentage of the image height for labels?
> Other options currently available already?
> Thoughts on this issue/enhancement appreciated.
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
