Google Maps / Virtual Earth map projection in MapServer
Dave Weaver
dave.weaver at ZEN.CO.UK
Fri May 18 02:50:11 PDT 2007
I'm trying to get my map in the same projection that's used by Google Maps &
Virtual Earth.
According to this article:
http://www.sharpgis.net/2007/05/05/SpatialReferencesCoordinateSystemsProjectionsDatumsEllipsoidsConfusing.aspx
the SRS string for the projection used is:
PROJCS["Mercator Spheric", GEOGCS["WGS84based_GCS",
DATUM["WGS84based_Datum", SPHEROID["WGS84based_Sphere", 6378137, 0],
TOWGS84[0, 0, 0, 0, 0, 0, 0]], PRIMEM["Greenwich", 0, AUTHORITY["EPSG",
"8901"]], UNIT["degree", 0.0174532925199433, AUTHORITY["EPSG", "9102"]],
AXIS["E", EAST], AXIS["N", NORTH]], PROJECTION["Mercator_1SP"],
PARAMETER["False_Easting", 0], PARAMETER["False_Northing", 0],
PARAMETER["Central_Meridian", 0], PARAMETER["Latitude_of_origin", 0],
UNIT["metre", 1, AUTHORITY["EPSG", "9001"]], AXIS["East", EAST],
AXIS["North", NORTH]]
How can I use this information in my map file to specify the output
projection of my map? (projections aren't my strong point!)
Thanks,
Dave.
More information about the MapServer-users
