Newbie python MapServer question
Matthew Perry
perrygeo at GMAIL.COM
Mon May 21 16:56:25 EDT 2007
John,
On 5/21/07, Ertl, John C CIV 63134 <john.ertl at navy.mil> wrote:
> David thanks, but It looks like FWTools is a full install of many
> things...I am not sure my systems guys would like that. It looks like
> it has an old version of Python...I need to run a newer version. I know
> you can run more then one version but it makes things confusing. Is
> there another way other than WFTools..
You can get python mapscript going pretty easily if you've built
mapserver from source. Check out mapscript/python/README
- matt
> -----Original Message-----
> From: UMN MapServer Users List [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On
> Behalf Of Fawcett, David
> Sent: Monday, May 21, 2007 11:24
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> Subject: Re: [UMN_MAPSERVER-USERS] Newbie python MapServer question
> John,
> An easy way to get Python MapScript is to install FW Tools. There is a
> Linux installer.
> Plus, with FWTools, you get OGR and GDAL.
> David.
> [mailto:MAPSERVER-USERS at LISTS.UMN.EDU] On Behalf Of Ertl, John C CIV
> 63134
> Sent: Monday, May 21, 2007 12:43 PM
> Subject: [UMN_MAPSERVER-USERS] Newbie python MapServer question
> The standard cry for help. I am interested in using MapServer
> with Python. I see there are examples of Python scripts but do I need
> to build Map server a special way or install a separate Python module
> (import mapscript) ? From what I understand MapServer is being used in
> my office by some others using Perl but I can not get a hold of them to
> find out more. I have Python 2.4 installed on a Linux system and I use
> it, but not sure how to hook into MapServer.
> Any help would be appreciated.
> Thanks,
> John Ertl
> Meteorologist
> FNMOC
> 7 Grace Hopper Ave.
> Monterey, CA 93943
> (831) 656-5704
Matthew T. Perry
http://www.perrygeo.net
"You never change things by fighting the existing reality.
To change something, build a new model that makes
the existing model obsolete" - R. Buckminster Fuller
