Too many open files on mapserv 4.10.1
Daniel Morissette
dmorissette at MAPGEARS.COM
Tue May 22 10:30:43 EDT 2007
Sorry for the late reply. That sounds like a leak of file handles,
perhaps you could use 'lsof' to find out which files are left open
(you'd have to do that before the script ends execution), and then file
a bug with all the details.
Daniel
Benedito A. Cruz wrote:
> Hello,
> I am upgrading my mapserv applications to a new server. It starts working
> with no problems, but after a while the mapserv application stops working.
> After a lot of tests i discovered that the following Perl program works OK
> using mapserv 4.2.0 in the old server , but returns with "Too many open
> files" using mapserv 4.10.1 in the new server (it opens 23 files and die):
> #!/usr/local/bin/perl
> $|=1;
> use mapscript;
> foreach (0..50)
> { print "$_ ";
> my $map = new
> mapscript::mapObj('/home/mapcria/bin/data/mapfiles/default.map') or die
> "Unable to open mapfile $!";
> undef $map;
> $./tooManyOpenFilesBug
> 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 Unable to open
> mapfile Too many open files at /home/xxx/tooManyOpenFilesBug
> Does anybody have a hint on the problem? I need it opening a lot of files,
> since I am using mapserv as a component of a web service and not as a CGI.
> The versions I am using in the new server are:
> Fedora Core 6 x86_64
> Kernel 2.6.18-1.2798.fc6 x86_64 x86_64 x86_64 GNU/Linux
> GCC 4.1.1 20070105 (Red Hat 4.1.1-51)
> PERL 5.8.8
> GDAL 1.4.0
> GD 2.0.33
> GEOS 2.2.3
> GEOTIFF 1.2.3
> PROJ 4.5.0
> []s
> Benê
Daniel Morissette
http://www.mapgears.com/
