Accessing images using time dimension.
    Dave Weaver
    dave.weaver at ZEN.CO.UK
    Wed May 23 02:38:15 PDT 2007
On 23/05/07, Dave Weaver <dave.weaver at zen.co.uk> wrote:
> and my URL looks like this:
>http://localhost:8080/cgi-bin/mapserv?map=/home/map/fgs/www/htdocs/maps/time.map&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=world,sat&WIDTH=800&HEIGHT=400&FORMAT=image/png&TRANSPARENT=false&BBOX=-90,-25,90,85&TIME=2007-05-11T11:00
> However, despite both the TIME in the URL and the wms_timedefault values
> showing 11:00, I can only ever see the 10:00 image
> If I use this URL instead:
http://localhost:8080/cgi-bin/mapserv?map=/home/map/fgs/www/htdocs/maps/time.map&mode=map&layers=sat
> And enable the FILTER line in the time_idx layer to select the 11:00 image,
>  I can see it. I just can't seem to get it working using a WMS request. Most
> frustrating!
Seeing as I was building mapserver from source anyway, I resorted to putting
extra debug output in mapwms.c, and  I can now see the problems.
1. msWMSApplyTime() is only applying the time if the relevant layer is ON or
DEFAULT - because my URL wasn't specifying the time_index layer in the
LAYERS= parameter, this layer was being ignored here.
2. msWMSApplyTime() seems to want both the wms_timeitem and wms_timeextent
itmes in the same layer, however the impression I got from previous replies
in this thread was that wms_timeitem was in the time_index layer, and
wms_timeextent should be in the RASTER layer.
Putting these things together, I added time_index to the LAYERS parameter of
the URL and moved the wms_timeextent and wms_timedefault items back to the
time_index layer, and now it seems to work.
Is this how it's supposed to be? Or am I making multiple errors that are
cancelling each other out?
Thanks,
Dave.
More information about the MapServer-users
