mapscript draw method is buggy on SDE layer
Ivano Picco
ivano.picco at AQUPI.TK
Wed May 23 09:39:08 PDT 2007
wrt my previous messages (
http://lists.umn.edu/cgi-bin/wa?A2=ind0705&L=mapserver-users&D=1&T=0&O=D&P=25025 )
I tried to replace mapserv with a simple mapscript (see attachment).
After a stress test (ArcSDE layer, 6 user, 10 connections at the same time, 5 minutes long,
lighttpd as webserver) 18 cgis still remain in memory (643 total connections). My script
saves the steps of execution on log files, so I can keep a track.
This is what i found on a log file of a "zombie":
PID:17932
Start:2007-05-2317:05:20
Creazione mappa:2007-05-2317:05:20
Reperimento layer:2007-05-2317:05:20
Preparazione Immagine:2007-05-2317:05:20
Disegno:
As you can see the process hangs on $layer->draw($map, $img);.
My tests with Oracle Spatial and OGR finished without any cgi process, like other made with
mapserv.
I hope this can be useful to found and solve this problem,
thanks,
Ivano Picco
Type: application/x-perl
Desc: not available
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070523/66e4b127/attachment.bin>
More information about the MapServer-users
