MapServer PostGIS connection: oids an gids to build a query
Fabio D'Ovidio
dovidio at PLANETEK.IT
Wed May 23 12:10:57 EDT 2007
I agree with you ! It is right!!
The problem is: a customer has sent me the database dump and the original data come
from sensors in automatic way. This is the reason for which database structure is so bad !!
I don't want to change it, so I have asked u a solution.
Thanks
On 23 May 2007 at 9:50, Gregor Mosheh wrote:
> > I have imported some geographical data (POINT) and their alphanumeric information in
> > PostgreSQL\PostGIS database. The structure of the database is WITHOUT OIDS and there
> > are no GIDs in the tables. So PK and FK are not numerical keys: they are string type keys!.
> Ouch! Mapserver does use the oid, and having an index on the oid is very
> helpful for performance. (this was the case with 4.8 anyway, has it
> changed in 4.10?)
> > So MapServer is able only to query data if they have integer ids in
> > PostGIS structure. WHY ??
> Mapserver/PostGIS queries by coordinate. "select where the_geom
> intersects" blah blah blah. I don't know about the other GIS software,
> but a unique identifier field, a primary key, is a pretty standard
> expectation.
> I'd say to always have numeric fields for both PKs and FKs, but that's
> just me talking on general principle.
> Gregor Mosheh / Greg Allensworth
> System Administrator, HostGIS cartographic development & hosting services
> http://www.HostGIS.com/
> "Remember that no one cares if you can back up,
> only if you can restore." - AMANDA
Ing. Fabio D'Ovidio
Staff Web GIS
Planetek Italia s.r.l.
Via Massaua 12, I-70123 Bari
Tel.: +39 080 5343750 Fax: +39 080 5340280
dovidio at planetek.it - http://www.planetek.it
