labels truncated at 256 chars
Francesco Sozzi
fsozzi at INTERCAD.CH
Thu May 24 03:00:10 EDT 2007
Hi Umberto!
Great!!! It works!
Thank you very much for suggestion.
Best regards
Francesco
----- Original Message -----
From: "Umberto Nicoletti" <umberto.nicoletti at GMAIL.COM>
To: <MAPSERVER-USERS at LISTS.UMN.EDU>
Sent: Thursday, May 24, 2007 8:46 AM
Subject: Re: [UMN_MAPSERVER-USERS] labels truncated at 256 chars
This is almost surely a limitation of oracle spatial.
You could try to recompile mapserver after editing the
maporaclespatial.c file at about line 58 where it says:
#define TEXT_SIZE 256
and set TEXT_SIZE to a higher number.
HTH,
Umberto
On 5/24/07, Francesco Sozzi <fsozzi at intercad.ch> wrote:
> Hi Steve and Fernando,
> Thanks for your support and fast answer.
> I am using Oracle Spatial 9i on Mapserver 4.10.1 compiled by Visual Studio
> .NET 2003 (Everithing very stable from several years).
> Do you think it is something related to Oracle?...
> Here you are my layer definition:
> LAYER
> NAME "Voli"
> TYPE POINT
> CONNECTIONTYPE oraclespatial
> CONNECTION "ti_externals/avs at franz"
> DATA "GEOM FROM (SELECT fid,label,geom FROM ic_voli) USING UNIQUE fid"
> LABELITEM "label"
> STATUS DEFAULT
> CLASS
> NAME 'Volo'
> SYMBOL 'circle'
> SIZE 10
> COLOR 255 0 0
> TEMPLATE "templates/default.html"
> LABEL
> COLOR 0 0 0
> TYPE TRUETYPE
> FONT arial
> SIZE 8
> ANGLE AUTO
> BUFFER 2
> OFFSET 0 -10
> FORCE TRUE
> WRAP '@'
> END
> END
> END
> Best regards
> Francesco
> From: "Steve Lime" <Steve.Lime at DNR.STATE.MN.US>
> Sent: Thursday, May 24, 2007 6:47 AM
> I created a quick test case using inline features and can render more than
> 256 chars, 322 in my example. Must be a data driver issue. What data
> source
> are you using? With shapefiles I thought the limit in a single column was
> 256 chars.
> Steve
> >>> Steve Lime <Steve.Lime at DNR.STATE.MN.US> 05/23/07 5:49 PM >>>
> I didn't think this was a limitation, lemme check and reply back...
> Steve
> >>> Francesco Sozzi <fsozzi at INTERCAD.CH> 05/23/07 7:20 AM >>>
> Hi All,
> Anybody has a workaround to display labels longer than 256 chars?
> Or may be any suggestions on where to modify mapserver code?
> Best regards
> Francesco
> __________ Informazione NOD32 2287 (20070523) __________
> Questo messaggio è stato controllato dal Sistema Antivirus NOD32
> http://www.nod32.it
http://www.nod32.it
