Again c# Unable to load DLL (mapscript)
sonj
sonj_you at YAHOO.CO.IN
Fri May 25 02:07:13 EDT 2007
I have solved my problem that is setting up httpd.conf ( Listen 8080,
ServerAdmin admin at abcd.com, ServerName abcd:8080)
Regards
sonj
sonj wrote:
> Hi,
> I need some help from all, I started MapServer installation and succeeded
> and I tested using http://Localhost.. it gives index page.. fine. My
> System having .Net1.1, from VS2003 I try to create a new website but it
> shows error ASP.Net Version Mismatch (see attachment ) then I veryfine my
> IIS there I found default web site stopped (see attachment). Please
> sugesst me where I could wrong ?
> Thanks - sonj
> Paolo Corti wrote:
>> I solved this (thanks again to Tamas for helping me)
>> On the first machine I solved building mapserver from the installation
>> toolkit.
>> it came out a very important thing when I was installing (this
>> afternoon) mapserver on another machine.
>> All the problems I had with my mapserver installation on my
>> development machine (unable to load dll mapscript...) can be easily
>> avoided without the need to build mapserver from the building kit.
>> It is sufficient to copy on the server the mapserver directory
>> distribuited as precompiled binaries (at
>> http://maptools.org/ms4w/index.phtml?page=downloads.html) on the
>> server and then include the path to the bin directory.
>> For example I extracted ms4w under c, and then i added at the PATH
>> environment variable this path: "C:\ms4w\Apache\cgi-bin" (under this
>> dir there are all the dll needed by mapscript) and now it is working
>> like a charm.
> http://www.nabble.com/file/p10735714/asp.netVersionMismatch.jpg
> http://www.nabble.com/file/p10735714/IIS.jpg
View this message in context: http://www.nabble.com/Again-c--Unable-to-load-DLL-%28mapscript%29-tf1975214.html#a10797586
Sent from the Mapserver - User mailing list archive at Nabble.com.
