Shapefile Join with MySQL table (2)
Steve Lime
Steve.Lime at DNR.STATE.MN.US
Fri May 25 14:55:07 PDT 2007
Are you getting an error or is it output via a template correct?
Steve
>>> On 5/24/2007 at 3:56 AM, in message
<LISTSERV%200705240356550326.DF58 at LISTS.UMN.EDU>, Adrià
<mapserver at GEODATA.ES>
wrote:
> Sorry for the wrong format of the previous message:
> Hi, I've been trying to join the features of a shapefile with records
of a
> MySQL table, following the instructions provided in the
documentation:
> http://mapserver.gis.umn.edu/docs/reference/mapfile/join
> I used the same directives used in the example of a join between a
shapefile
> and a postgreSQL table,changing the syntax for MySQL connections in
the
> CONNECTION directive, but without success:
> JOIN
> NAME "join"
> CONNECTIONTYPE OGR
> CONNECTION
"dbname,host=localhost,port=3306,user=*****,password=*****"
> TABLE "municipis"
> FROM "codiine"
> TO "CodIne"
> TYPE ONE-TO-ONE
> END
> The same syntax works fine in ogrinfo:
> ogrinfo
MYSQL:"dbname,host=localhost,port=3306,user=*****,password=*****"
> lookup -summary
> All table, field names, etc are double checked. Any ideas? Could
anyone who
> has done it before share his JOIN code in the map file? Thanks in
advance
More information about the MapServer-users
