Layer display order (z-index)?
Jackey Cheung
cheung.jackey at GMAIL.COM
Tue May 29 05:06:16 EDT 2007
Greetings!
I've put some roads, polygons and poi to my map, their order in the map file is: polygon layers go first, then road layers, and the poi layer is the last. A picture is generated like this: http://www3.mapasia.com/jackout/mapserv.png
As you can see, those 2 POI icons are covered by roads, can I make those POI icons always on top of everything else in the map?
I've tried re-ordering layers in the map file, but the icons are kept covered by roads.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20070529/17126fbe/attachment.html
