Solaris 8 Help - Compiling Supporting Libs
    Gregor Mosheh
    gregor at HOSTGIS.COM
    Tue May 29 11:46:29 PDT 2007
> I'm looking for any resources people might have on successfully compiling
> the supporting MapServer libraries. Proj.4 installed just fine. Compiling
> the GDAL library fails the make with "make: Fatal error: No arguments to
> build". I can see that there is no Makefile only a GNUmakefile. If I try to
> run "make -f GNUmakefile" it errors out in reading the GDALmake.opt at line
> 10. Anyone have success compiling the GDAL library on Solaris?
Solaris is always a pain, since it usually has a combination of both GNU
and non-GNU utilities. For instance, try using "gmake" to make sure that
it's using GNU's make rather than Sun's version of make.
Gregor Mosheh / Greg Allensworth
System Administrator, HostGIS cartographic development & hosting services
http://www.HostGIS.com/
"Remember that no one cares if you can back up,
  only if you can restore." - AMANDA
More information about the MapServer-users
