Perl mapscript reprojecting WKT issues
Kralidis,Tom [Burlington]
Tom.Kralidis at EC.GC.CA
Tue May 29 19:32:59 EDT 2007
Tamas,
Thanks for the info. Trying this via python yields the same results as
Perl:
import sys, mapscript
projInObj = mapscript.projectionObj("init=epsg:4326")
projOutObj = mapscript.projectionObj("init=epsg:42304")
shape = mapscript.shapeObj.fromWKT("POINT(-75 45)")
print shape.toWKT()
if shape.project(projInObj, projOutObj):
print "Success"
else:
print "Can't reproject"
sys.exit(2)
print shape.toWKT()
> -----Original Message-----
> From: Tamas Szekeres [mailto:szekerest at gmail.com]
> Sent: 29 May, 2007 5:32 PM
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER-USERS at lists.umn.edu
> Subject: Re: [UMN_MAPSERVER-USERS] Perl mapscript
> Tom,
> I've tested the equivalent code with c# and Windows, here's
> the output of the program:
> POINT (-75 45)
> POINT (1578125.6146771896 -198241.98781270601)
> I cannot decide whether the results are correct, but it
> does't crash anyway.
> Best regards,
> Tamas
> 2007/5/29, Kralidis,Tom [Burlington] <Tom.Kralidis at ec.gc.ca>:
> > > Kralidis,Tom [Burlington] writes:
> > > > Hi,
> > > > MapServer 4.10.0
> > > > FreeBSD
> > > > I have a Perl script where I'd like to reproject a WKT
> > > string. Here's
> > > > the code:
> > > > #!/usr/bin/perl
> > > > use strict;
> > > > use warnings;
> > > > use mapscript 4.10.0;
> > > > my $projInObj = new mapscript::projectionObj("init=epsg:4326");
> > > > my $projOutObj = new
> mapscript::projectionObj("init=epsg:42304");
> > > > my $shape = mapscript::shapeObj::fromWKT("POINT(-75 45)");
> > > > print $shape->toWKT()."\n";
> > > > $shape->project($projInObj, $projOutObj) || die "Can't
> reproject:
> > > > $!\n";
> > > > The script dies on the shapeObj project call.
> > > > Any suggestions or ideas?
> > Can anyone run this script (you might have to change
> epsg:42304 if you
> > don't have it defined in your proj epsg file) successfully?
> > I notice that this functionality was as a result of RFC2
> > (http://mapserver.gis.umn.edu/development/rfc/ms-rfc-2). Just not
> > sure if it's my syntax that's off or if this could be a
> potential bug?
> > ..Tom
