Weidr Output image with the esri tile index file -- GDALTINDEX
Zhonghai Wang
zhonghaiw at GMAIL.COM
Mon Oct 1 12:50:27 EDT 2007
Actually, the white lines only appears on this tile index file, all the
others are fine. What I am worrying about is what you said - the gaps
between image georeferencing, but I am not really sure. My images are just
400*^300 pixels, so if I get a image rendered by MapServer, i can see the
white grids on the every output image.
Am I the only one who gets the white lines on output image?
Zhonghai
On 10/1/07, Christopher Harris <docterrobert at msn.com> wrote:
> Just throwing this out there, but I recently created a tile index using
> gdaltindex. I did not get the white lines you are talking about. It could
> be that there are gaps in between the tiles, which would point to the
> georefencing info for each tile being slightly off. Also, are you zoomed
> way out? Try zooming in close and see if they are still there. The
> tile-indexed image I have is huge (2602 X 2800), so it looks funny when
> zoomed all the way out when trying to view the entire image - still no lines
> though. Also, try using a .gif or .png instead of a .jpg and see what
> happens. Just some suggestions. That's all I really have. I'm just
> another Mapserver user - not an admin.
> - Chris
> Date: Mon, 1 Oct 2007 16:50:46 +0200
> From: zhonghaiw at GMAIL.COM
> Subject: [UMN_MAPSERVER-USERS] Weidr Output image with the esri tile index
> file -- GDALTINDEX
> To: MAPSERVER-USERS at LISTS.UMN.EDU
> HI guys,
> I've created a tile index file with the GDALTINDEX utility for my small
> raster jpeg images, all things work well, but the end output jpeg image with
> MapServer is a little weird, there are some white grid lines on the output
> image. I don't know if there are some blank areas between the tile images
> when creating the tile index file, or the tile index grid are drawn by
> MapServer on the output jpeg image.
> attached is a small example output jpeg image.
> any clues are welcome.
> Best Regards
> Zhongahi
> Invite your mail contacts to join your friends list with Windows Live
> Spaces. It's easy! Try it!<http://spaces.live.com/spacesapi.aspx?wx_action=create&wx_url=/friends.aspx&mkt=en-us>
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071001/6e285395/attachment.html
