Transparent raster layer (with Jpegs source rasters)
Pedro Mendes
mendes at GAVETA.NET
Tue Oct 2 06:59:37 EDT 2007
Frank,
Thanks! it was just what I needed!
I only have to set the expression to a higher value - [pixel] < 150 - to
render all the pixels I want.
Thanks again!
Cumps, Pedro
Frank Warmerdam-2 wrote:
> On 10/1/07, Pedro Mendes <mendes at gaveta.net> wrote:
>> Hi people,
>> I´m trying to display a raster layer from a tileindex file (.shp). The
>> source rasters for this shapefile are jpeg with the following info:
>> My prob is that i can´t force mapserver only to render the black color in
>> the rasters (i tried changing several parameters in the layer object, and
>> using different output declarations). If it´s possible can u show it to
>> me?
>> The output format isn´t important, just wanna get fully transparent
>> layers
>> (in colors grey and white, keeping black).
> Pedro,
> My understanding is that you want black (0,0,0) in your
> source raster to be rendered, and all other values to be
> treated as transparent ... is that right?
> The only mechanism that comes to mind to accomplish
> this is to define a class for pixel value 0 with a color
> of 0,0,0 and no other classes so all other values will
> appear as transparent. Something like:
> CLASS
> EXPRESSION ([pixel] = 0)
> COLOR 0 0 0
> END
> You may find that the source jpeg file has corrupted some
> black pixels causing them to have values near zero but not
> quite equal to zero. to capture these too, you might change
> your expression to be something like [pixel] < 5.
> Good luck,
> I set the clouds in motion - turn up | Frank Warmerdam,
> warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
View this message in context: http://www.nabble.com/Transparent-raster-layer-%28with-Jpegs-source-rasters%29-tf4549266.html#a12996665
Sent from the Mapserver - User mailing list archive at Nabble.com.
