Transparency in JPGs on windows
Frank Warmerdam
warmerdam at POBOX.COM
Tue Oct 2 11:00:32 EDT 2007
On 10/2/07, Gabe <gabe at agtrix.com> wrote:
> Hi
> We are running several instances of mapserver on Linux and Windows.
> I have some maps that display a tiled aerial photography layer and some
> other vector layers. The vector layers are polygons displayed using a
> symbol with a transparent background. While the photography is switched off
> the map is produced as a png and all works as expected. However when the
> photography layer is on (and the image is produced as a jpg) the vector
> layers no longer have any transparency and use instead the map background
> colour.
> That happens on the windows boxes but not on the linux boxes. The
> installations are as similar as possible and this effect has been consistent
> since about mapserver 4.8 (now using 4.10.2 and 5.0.0)
> Is there a fix for this ?
Gabe,
JPEG files do not support transparency so as long as the output
format is JPEG there is no way to return files with transparent areas.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
