Any help appreciated!! - Fwd: 5.0 - use of
qstring_validation_pattern for attribute queries
Mike Saunt
mikesaunt at GMAIL.COM
Wed Oct 3 06:45:27 EDT 2007
Hi All
For completeness I thought I'd let people know - I've got this solved now -
I wasn't on the 5.0 release version (doh!) and map file is like this to let
any query through
METADATA
qstring_validation_pattern '.'
END
Thanks
Mike
On 28/09/2007, Umberto Nicoletti <umberto.nicoletti at gmail.com> wrote:
> Try:
> On 9/28/07, Mike Saunt <mikesaunt at gmail.com> wrote:
> > Hi All
> > I sent this out earliler in the week - has anyone used a 'qstring' in
> > MapServer 5.0 where the pattern should be able to match any string? I
> can't
> > seem to get it to work even though I get messages back such as Failed to
> > parse expression: Mendip = Mendip msyyparse(): Expression parser error.
> > parse error msEvalExpression: Expression parser error.
> > Would there be any examples in the test cases / data etc?
> > Cheers
> > Mike
> > Hi All
> > I was wondering whether anyone has an example of the METADATA key for
> > qstring_validation_pattern that is required for v5.0 layers that are to
> be
> > attribute queried?
> > I would like to be able to accept any string (as through my app you
> can't
> > inject the values)
> > I've tried the following qstring_validation_pattern /^[0-9]*$/ and
> > qstring_validation_pattern '.' but neither seem to match (the first
> throws a
> > symbol definition error):
> > LAYER
> > NAME Ward
> > TYPE POLYGON
> > STATUS OFF
> > CONNECTIONTYPE OGR
> > CONNECTION
> > "Overlays\CouncilDemocracy\Ward_Boundaries_2004.TAB"
> > TOLERANCEUNITS METERS
> > METADATA
> > END
> > CLASS
> > STYLE
> > COLOR -1 -1 -1
> > END
> > STYLE
> > OUTLINECOLOR 0 0 0
> > WIDTH 2
> > END
> > END
> > END
> > I've also tried as TYPE QUERY...
> > Any help would be greatly appreciated
> > Cheers
> > Mike
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071003/9b01175b/attachment.html
