SLD issues
Yewondwossen Assefa
assefa at DMSOLUTIONS.CA
Fri Oct 5 09:41:40 EDT 2007
Jacolin Yves wrote:
> Hi list,
> I am trying to setup a SLD file for a layer. I create a SLD file:
> <StyledLayerDescriptor version="1.0.0">
> <NamedLayer>
> <Name>geosignal</Name>
> <NamedStyle>
> <Name>xxx</Name>
> </NamedStyle>
> <UserStyle>
> <FeatureTypeStyle>
> <Rule>
> <RasterSymbolizer>
> <Opacity>0.6</Opacity>
> </RasterSymbolizer>
> </Rule>
> </FeatureTypeStyle>
> </UserStyle>
> </NamedLayer>
> </StyledLayerDescriptor>
> Which the aims is to change the opacity.
> My url is:
> http://www2.xxxx.com/cgi-bin/mapserv_wms?
> LAYERS=orthophoto,geosignal,sncf&
> TRANSPARENT=true&
> FORMAT=jpeg&SERVICE=WMS&VERSION=1.1.1&
> REQUEST=GetMap&EXCEPTIONS=application-vnd.ogc.se_inimage&
> STYLES=,,&SLD=http://www2.xxx.com/lpdi/sld/geosignal.xml&
> SRS=EPSG:27582&
> BBOX=579452.7126630786,2420705.106583846,608239.3637849536,2441871.7618205184&
> WIDTH=680&HEIGHT=500
> My geosignal layer is not transparent. Do I need to do something to mapserver
> side (build, configuration)? I didn't change anything in my mapfile. Am I
> right?
> Regards,
> Y.
You are right that there should not be any changes needed in the map
file. Make sure that you have built MapServer with OGR support (USE_OGR).
The SLD seems to be valid from what I can see. From your settings it
should have the same effect as setting the OPACITY value on the
geosignal layer to 60. Does setting the opacity value manually in your
layer and not using the sld gives you the expected result ?
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
