Can't get .png Location Marker to show transparencies via code
Christopher Harris
docterrobert at MSN.COM
Fri Oct 5 13:51:08 PDT 2007
Hi. I have been trying to figure this out for quite a while. I have this working within a .map file, but if I set it up exactly the same way with php, it never works. I'm using Firefox to test it, not IE6 (in case someone thinks it's due to IE6 not supporting .png's. The .map file contains the first marker, which works. The .php file attempts to make the second marker use a transparent background. One interesting thing that I've noticed is if I add jibberish to the parameter in this line: $markerLayer->set(transparency, MS_GD_ALPHA); so as to make the app break, nothing happens. The app doesn't throw up any error messages and continues to render the second marker without transparencies.
Here is my .map file that works. I put the United States example off the mapserver site to use as a "background" so I could pin my markers via lat/lon and know where I was. So, that's why that's there. I could give a crap about all that. The marker layer is at the bottom.
NAME USA1
STATUS ON
DEBUG ON
SIZE 800 500
IMAGETYPE PNG
IMAGECOLOR 140 140 140
SHAPEPATH "/var/www/mapserver/campuscomber/data/statesp020/"
EXTENT -89.248281 39.082274 -87.205980 41.117268
UNITS DD
PROJECTION
"proj=latlong" "ellps=GRS80" "datum=NAD83"
END
WEB
IMAGEPATH "/var/www/mapserver/campuscomber/images/"
IMAGEURL "/mapserver/campuscomber/images/"
END
OUTPUTFORMAT
NAME gif
DRIVER "GD/GIF"
MIMETYPE "image/gif"
IMAGEMODE RGBA
EXTENSION "gif"
END
OUTPUTFORMAT
NAME png
DRIVER "GD/PNG"
MIMETYPE "image/png"
IMAGEMODE RGBA
EXTENSION "png"
END
LAYER
NAME "US state boundaries"
TYPE POLYGON
STATUS ON
DATA "statesp020"
PROJECTION
"proj=latlong"
"ellps=GRS80"
"datum=NAD83"
END
CLASS
NAME "US states"
OUTLINECOLOR 0 0 0
COLOR 80 80 0
SYMBOL 0
END
END
LAYER
NAME "credits"
STATUS DEFAULT
TRANSFORM FALSE
TYPE ANNOTATION
FEATURE
POINTS
10 480
END
TEXT 'Made with Mapserver.'
END
CLASS
LABEL
TYPE BITMAP
POSITION CR
COLOR 250 250 0
END
END
END
LAYER
NAME "Marker"
TYPE POINT
STATUS DEFAULT
TRANSPARENCY ALPHA
CLASS
STYLE
SYMBOL 'data/statesp020/red_dot.png'
SIZE 15
END
END
FEATURE
POINTS
-88.228841 40.104796
END
END
END
END
Here's the .php file with marker #2:
<?php
//dl("php_mapscript.so");
$map_file="./markerTest.map";
$map = ms_newMapObj($map_file);
$markerLayer = ms_newLayerObj($map);
$markerLayer->set(name, "Marker2");
$markerLayer->set(type, MS_LAYER_POINT);
$markerLayer->set(status, MS_DEFAULT);
//Location Marker layer class
$markerClass = ms_newClassObj($markerLayer);
//Location Marker layer class style
$markerStyle = ms_newStyleObj($markerClass);
//Gives the location of the symbol to place as a marker
$markerStyle->set(symbolname, "data/statesp020/red_dot.png");
//Sets the size of the marker. The bigger, the badder.......
$markerStyle->set(size, 15);
$image=$map->draw();
$markerPoint = ms_newPointObj();
$markerPoint->setXY(-88.227167, 41.015752);
$markerLine = ms_newLineObj();
//$markerLine->addXY(-88.227167, 41.015752);
$markerLine->add($markerPoint);
$markerShape = ms_newShapeObj(MS_SHAPE_POINT);
$markerShape->add($markerLine);
$markerLayer->addFeature($markerShape);
$layer=$map->getLayerByName("Marker2");
//Draws the point using the map, layer Marker2, and the image generated
$markerShape->draw($map, $layer, $image);
$image_url=$image->saveWebImage();
<html>
<head>
<title>US state boundaries and Marker Test</title>
</head>
<body>
<img src="<?php echo $image_url?>">
<p>
Marker Test
</p>
</body>
</html>
Thanks in advance.
- Chris
_________________________________________________________________
Boo! Scare away worms, viruses and so much more! Try Windows Live OneCare!
http://onecare.live.com/standard/en-us/purchase/trial.aspx?s_cid=wl_hotmailnews
URL: <http://lists.osgeo.org/pipermail/mapserver-users/attachments/20071005/be20e79e/attachment.htm>
More information about the MapServer-users
