SLD issues
Jacolin Yves
yjacolin at FREE.FR
Mon Oct 8 05:30:47 EDT 2007
Le Monday 08 October 2007 10:14:41 Jacolin Yves, vous avez écrit :
> Le Friday 05 October 2007 15:41:40 Yewondwossen Assefa, vous avez écrit :
> > Jacolin Yves wrote:
> > > Hi list,
> > > I am trying to setup a SLD file for a layer. I create a SLD file:
> > > <StyledLayerDescriptor version="1.0.0">
> > > <NamedLayer>
> > > <Name>geosignal</Name>
> > > <NamedStyle>
> > > <Name>xxx</Name>
> > > </NamedStyle>
> > > <UserStyle>
> > > <FeatureTypeStyle>
> > > <Rule>
> > > <RasterSymbolizer>
> > > <Opacity>0.6</Opacity>
> > > </RasterSymbolizer>
> > > </Rule>
> > > </FeatureTypeStyle>
> > > </UserStyle>
> > > </NamedLayer>
> > > </StyledLayerDescriptor>
> > > Which the aims is to change the opacity.
> > > My url is:
> > > http://www2.xxxx.com/cgi-bin/mapserv_wms?
> > > LAYERS=orthophoto,geosignal,sncf&
> > > TRANSPARENT=true&
> > > FORMAT=jpeg&SERVICE=WMS&VERSION=1.1.1&
> > > REQUEST=GetMap&EXCEPTIONS=application-vnd.ogc.se_inimage&
> > > STYLES=,,&SLD=http://www2.xxx.com/lpdi/sld/geosignal.xml&
> > > SRS=EPSG:27582&
> > > BBOX=579452.7126630786,2420705.106583846,608239.3637849536,2441871.7618
> > >20 5184& WIDTH=680&HEIGHT=500
> > > My geosignal layer is not transparent. Do I need to do something to
> > > mapserver side (build, configuration)? I didn't change anything in my
> > > mapfile. Am I right?
> > > Regards,
> > > Y.
> > You are right that there should not be any changes needed in the map
> > file. Make sure that you have built MapServer with OGR support (USE_OGR).
> > The SLD seems to be valid from what I can see. From your settings it
> > should have the same effect as setting the OPACITY value on the
> > geosignal layer to 60. Does setting the opacity value manually in your
> > layer and not using the sld gives you the expected result ?
> Hi,
> Thanks for your answer Yewondwossen Assefa. I check my mapserv cgi and, yes
> it was built with OGR (INPUT=OGR). If I change/add the TRANSPARENCY
> parameter to 60, all is working fine.
> Do you think I don't use the correct parameter ? The mapfile don't use
> OPACITY as valid parameter (except for the 5.0, and I am using the 4.10.1
> release).
> Y.
Hi again ;)
I succeed to use a SLD service with my WMS map. My problem came from the
abscence of this part:
WEB
IMAGEPATH "/tmp/"
END
Regards,
Y.
Yves Jacolin
http://softlibre.gloobe.org
